Question about Shop Vac (464-38-10) Canister Wet/Dry Vacuum
I plugged in my new wet/dry shop vac and smoke came out and burned the motor? What did I do wrong
Buffalo12980
  • 625 Answers
SOURCE: shop-vac i lost book
open the top of the vacuum. remove ONLY the filter element. There should be a ball about a two inch diameter inside the cage. It's purpose is to shut off the vacuum flow when water reaches a high in the canister.
Posted on Aug 29, 2007
SOURCE: shop vac Wet/Dry Vacuum 2.0
How do you make a Shopvac wet/dry vacuum blow out air
Posted on Feb 08, 2008
Agent Don
  • 310 Answers
SOURCE: Shop Vac 12 wet dry canister
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=245090
Posted by Fa Fa on Nov 05, 2007
I'm not certain I have all the parts to my Shop Vac. I have no instructions so I need help describing how it works and a picture of the main parts.
Thanks for any help. Julia Harris
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Posted on Jun 09, 2008
rickzilla
  • 706 Answers
SOURCE: Help!!! It won't start.
When you say you checked your extension cord, what do you mean by that? Were you able to ohm out the wires to determine that you didn't have an inline break anywhere? Just because you changed outlets to a known good outlet, doesn't rule out a problem with the cord, switch or motor itself. If you have access to an ohm meter, volt meter, continuity checker or even an inductive power sensor ( electritians use these all the time to find live power feeds) then you may be able to determine where the problem lies.. I did a cursory search for a wiring diagram for that particular model but was unable to locate one. Not having that information means I am only speculating what your problem could be. Is there a reset button or popout circuit breaker on that model that may have tripped? If so, reset it and try it again. If not then you may need to do some troubleshooting of the hardware itself. Not sure I've helped you at all but I tried.. Hope you can trace out the problem... Good luck..
Posted on Sep 04, 2008
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
I can't find the owner's manual to our shop vac. What's involved in converting it from a dry vac to a wet vac? I think it does both, but I've only ever used it to clean the car.
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
Jul 23, 2011 | Shop Vac 5841627 Wet/Dry Vacuum
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
My new shop vac is smoking and smells like electrical fire. Any suggestions? Should I just take it back to the store?
Hi. ABSOLUTELY return it. It has an internal electrical issue which may cause a fire. Return it ASAP!! J.
Aug 09, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Sep 17, 2008 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Motor
Replace the motor... if you live in canada, go to canadian tire or part source they'll have what oyu need to fix it.
Jun 24, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop Vac (464-38-10) Canister Wet/Dry Vacuum Logo
520 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
