Question about Konica Minolta PagePro 1350W Laser Printer
Just had a toner cartridge refill. The printer works but it still does not print
    Problem Solver:
  • 5 Answers
Usually, there is a little hole on the side of the cartridge of ink, it like the reset button of your old nintendo. so if you want your printer to consider you before empty cartridge full, push the reset button that is near the part that the ink exits and it sould work great. you can even reset your cartridge when its says its empty, sometimes its not even really empty and you can go for some other miles whit it
(sorry for my english, i usually speak french)
Posted on May 19, 2011
  • 63 Answers
  • On laser printers, there is a "print head", and this could have died. I would try replacing the toner cartridge with a known good, barring that, the print head itself might have to be replaced.
    I am very familiar with replacing the print head on Lexmark laser printers, but I cannot speak for the Konica Minolta line as far as replacing it.
    Depending on the value and age of the printer, you might want to replace it rather than replace the print head as well.
  • It could also be a charge roller gone bad. This is the piece that goes in to the toner cartridge when you close the door, you can see where that is by closing the door partially with the toner cartridge out. If it is very dirty, you can try cleaning it with Isopropyl Alcohol and letting it dry FULLY before putting it back in place.
4 Suggested Answers
SOURCE: Cartridge advancement to replace toner
It's done via the printers internal menu system: On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Posted on May 09, 2007
  • 214 Answers
SOURCE: How to reset Black Toner Empty Message on 2430Dl
There are many problems like that and its not recommended to change toner from one printer to another.
but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
if thats not helping, then maybe you have a old FW so you can try to update the firmware.
Posted on Feb 09, 2008
SOURCE: I refilled my toner cartridge and the printer does
On the 2300 model there is a small tab that has to be pushed in when you refill it so the unit knows its been replaced. Look on the end and you will see two slots, one of which leads to a channel that the tab is in. Use a small screw driver to push the tab back towards the center of the cartridge. Don't try to do it from the top, use insert it into the end opening only or you may break the tab off.
Posted on Apr 04, 2010
I have Samsung ML-1666 Laser Printer. I am getting
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jun 02, 2012 | Samsung Office Equipment & Supplies
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 27, 2012 | Xerox Phaser 6280 Clr Laser Printer 26Ppm...
How to refill toner manually
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing the tonercartridge and shaking the toner cartridge in a horizontal position a few timesand then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 17, 2012 | HP Office Equipment & Supplies
How to refilling toner in canon lbp2900b
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Aug 29, 2011 | Canon LASER SHOT LBP-2900 Printer
Refill toner
Jul 26, 2011 | Canon LASER SHOT LBP-2900 Printer
I will refilling in toner Samsung scx 4x21 printer but display is toner empty what to do sir
Jun 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling...
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 25, 2011 | Office Equipment & Supplies
Hello, I own a Samsung Laser Printer SCX-4600. The initial toner is about to get finish. I am not sure whether to go for a replacement or to just refill the toner. Its the first time.
Mar 20, 2011 | Samsung SCX 4600 multifunction Laser...
Just how to refill the printers powder in the toner
Feb 26, 2011 | Canon LASER SHOT LBP-2900 Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
237 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
