Question about Onkyo TX-NR1000 Receiver
Onkyo tx nr-1000 intermittent sound cuts off
I am experiencing intermittent sound cutting off from my receiver. If I turn it off and wait a few minutes it comes back on, but within 5 minutes or so it's off again. I still get a picture from HDMI signal (have sound running through optical) and there is no sound through out all the output source i.e. tuner, dvd, etc. Does it need pro service? what could be the cause?
any help would be appreciated!
Thanks!
Pezlo
  • 2kellyman4 Feb 22, 2009
    HDMI module seems dead. All other functions intact. When in setup mode video flickered 3 times then blacked out, throughput was also lost. Unit was recently transported, should I reseat the module?
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
  • 14 Answers
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Posted on Dec 13, 2007
DickCanFixIt
  • 948 Answers
SOURCE: How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Posted on Jan 01, 2009
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
My Onkyo TX-NR838 switches off when I turn the tv off. I can't switch the receiver back on for 2 days
sounds like a faulty cable or psu .... or some bad solders on the back of a scart socket if you use scart
if not its something to do with TV detection the TX-NR unit uses
Dec 04, 2014 | Onkyo 7.2 Channel Network A/V Receiver -...
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
Have an onkyo txsr501 w/jbl scs135 surround sound sys, i disconnected it to paint room and when I hooked it back up the sub worked for about 15 mins than stopped went to standby, if i turn off the sub and...
If there is a way to cut and resplice the speaker wires at both the receiver and the speaker connections, try that. A good clean cut with no hanging copper wires is key.
Nov 25, 2009 | Onkyo TX-SR501 Receiver
Zone 2 cut off on onkyo
Your program source may not support a 7.1 format. Try switching to 5.1
May 06, 2008 | Onkyo TX-SR605 Receiver
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
Open Questions:
Onkyo TX-NR1000 Receiver Logo
102 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
