Question about Whirlpool Washing Machines
I have a stakable whirlpool thin twin 98, and it fills with water normally but doesn't do anything after that (no sounds at all). I have already replaced the "lid switch" for a new one, but nothing changed. The dryer is working fine, but not the washer. That problem started since I moved it from my old house and I did it laying the machine down on its back..
  • 4 more comments
  • flaviojavila May 19, 2011
    Thanks Ginko for your help. If I cannot lay that washer what you recommend to reach the motor underneath? Don't you think it could be also a belt problem?
    Ginko,
    This is a stakable washer/dryer whirlpool, the dryer is a front loader and it s at the top. The washer is at the bottom and it s a top loader.
    So, I still reach the motor and belts from the rear panel?
  • flaviojavila May 20, 2011
    whirlpool thin twin year 2008 model # LTE5243DQ6
    that machine laying on its back for 12 hours is a long time as you said?
    Ginko was very helpfull. Thanks
  • Whirlpool Master
  • 19,396 Answers
Hi.
The motor is not starting. If the machine has been laying in the incorrect position it may be a wiring problem. The motor is accessed from underneath, and if the appliance is stacked it may result quite complicate.
After reaching motor, wiring must be tested. The motor itself must be tested by Ohming it. Parts location and testing are the same as for this similar Maytag stack washer shown in this service manual
Parts numbers are different. To locate parts enter model number here.
Ginko
Posted on May 19, 2011
  • 2 more comments
  • Ginko
    Ginko May 19, 2011
    Hi.
    I am really sorry. This machine is obviously a front loader. I gave you instructions for the top loader (direct drive) that I was doing in the other thread.
    With this machine the belt and the motor are accessed altogether. The problem is likely belt or motor.
    To access belt and motor remove the rear access panel held by four hex head screws. The procedure is the same as the one for the Maytag illustrated in the service manual provided in my previous post.
  • Ginko
    Ginko May 19, 2011
    The top loader has no belt, it is direct drive. If it is a top loader, then the motor is accessed from the bottom. If you give me the full model number I will find the schematics for the proper model.
  • Ginko
    Ginko May 20, 2011
    Hi.
    The washer is a top load direct drive. THere is no belt, the only belt used is from the dryer. The motor is accessed from underneath. Here the cabinet. There is no panel at the back. The front panel comes back after removing the top. The motor is at the base and it is accessed from bottom.
    If the washer has been left laying on one side for a long time, the gearcase may have also been damaged. The first part to check is the motor.
    Here all parts and diagrams.
  • Ginko
    Ginko May 20, 2011
    12 hours is not such a long time. I thought the machine had been stored on one side.
    Appliances can get damaged when they do not stay upright. Hopefully the problem is only a lose connector. The only way to find out is inspecting the inside of the machine. Check connectors at motor, and the connectors to control module at the top.
    If you need a technician to do the job use the number listed on the owners manual.
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
I have a electric whirlpool thin twin. It fills with water and agitates...then nothing. No drain, or spin.
check the lid switch,open the lid and on the right side you'll see a hole in the top panel,stick a screw driver in it,push down,you should hear a click,or close the lid and open it a couple of inches and close it,do this a few times,no clicking sound bad lid switch.
Sep 12, 2011 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin problem
First be sure you're getting power to the motor this could cause both problems. If getting power then
sounds like you have 2 problems.
Dryer
On the heating problem be sure you have 220 volts at the power block, check the heating element , thermostats & high temp cutoff with an ohmmeter. Also check the centrifical switch on the motor it keeps the heat off for safety till the motor is up to speed so the fan is working.
Washer
Check lid switch some machines won't do anything but fill with the lid open . To check lid switch push the the switch down with a small screwdriver. If switch is ok check the coupler between the motor & transmission it can cause no agitate or spin. If all these are ok you may have a transmission problem. Last resort may be timer or wireing.
Nov 20, 2017 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
