Question about Samsung WEP650 Bluetooth Headset
I can not connect my wep650 samsung blue tooth to my samsung epic4..
    President:
  • Samsung Master
  • 1,118 Answers
Starting with your headset turned off, press and hold the call button for some seconds as if you were turning it on, but keep the button pressed until its indicator light is steadily lit. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a little while, you headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There could be an indication on your phone that a headset is connected too.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you out any further.
Regards,
Carlos
Posted on Jun 30, 2011
Where do I find the pairing code number pls.
No where from the specs of this model it does not have Blue Tooth capabilities. From the user manual there is no Blue Tooth capabilities. Pairing code would be for Blue Tooth.
You could use a 802.11N WI FI ethernet device and connect the TV to it but no blue tooth .
Mar 02, 2015 | Samsung Televison & Video
How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
Disconnect it first. means power off. unpair the device restart devices pair it again.
Oct 11, 2017 | Samsung Intensity II SCH-U460 Grey Verizon...
What is the numeric pass key for Samsung WEP650
The pass key that has to be entered for activation is 0000.
Sep 30, 2010 | Samsung WEP650 Bluetooth Headset
Trying to sync samsung wep650 but asks for a pass key. i dont know it
My experience has always been default wep numbers are set as 0000
Sep 22, 2010 | Samsung WEP650 Bluetooth Headset
How do i work bluetooth on a samsung n150
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 25, 2010 | Samsung SCH-n150
How to connect samsung mobile internet without pc suite?
I found A PC blue tooth at wallmart for less that 20 bucks, transfers pics audio everything on all my cells. plugs into usb port all you have to do is install disc from blue tooth, make blue tooth on and visible on cell phone then pair them code 0000
Jun 02, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I want to connect my Blue tooth device to my BlackBerry 8530 and I don't know how- This Bluetooth device used to be connected to a cellphone I had over a year ago- Now I have the NEW BlackBerry 8530... but...
In order to pair this headset with your BlackBerry, you need to place the headset in to pairing mode. To do this, press and hold the talk button until the indicator light turns blue and stays lit after blinking.
After you do this, go to the bluetooth setup area and search for a device. Once it locates your headset, it will prompt you for a PIN. This PIN should be the factory default, 0000. I hope this helps!
Mar 21, 2010 | Samsung WEP650 Bluetooth Headset
Not working Bluetooth in my Samsung Mobile Model No.SGH-X820
try an antivirus called net protector . load net protector on your main pc, use a cable to connect your mobile to pc using a compatible software for data transfer.
mobile will get detected in the antivirus software,SCAN YOUR MOBILE may be u are lucky to get blue tooth woking , if the file has come through blue tooth netwoking , pushed by some one when blue tooth was on some time. OTHER WISE do a factory reset and save all data first.
if this too fails then the blue tooth hardware/software has to be rectified.
Sep 20, 2009 | Samsung SGH-X820 Phone
I dont know how to get my samsung wep650 bluetooth headset into pair mode
please turn on your bluetooth setting.then connect the headset.
Aug 28, 2009 | Samsung WEP650 Bluetooth Headset
Samsung WEP650 Bluetooth Headset Logo
112 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
