Question about Kodak EasyShare C180 Digital Camera
Put fresh batteries in and tried to turn camera on to no avail
  • 43,501 Answers
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Posted on May 19, 2011
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
When i turn on, it says lens error, restart camera - i"ve turned the camera on and off several times and nothing happens, the error message continues to show. I've taken the battery out and put back in but...
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 05, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
I put new batteries in and it still says battery dead. is there a battery within the camera also
silly question, but have you tried different fresh batteries? sometimes batteries go dead in the store, especially if they are cheap batteries. try another fresh set.
Mar 21, 2010 | Canon PowerShot S2 IS Digital Camera
It turns on and off by it self
The battery enclosure has a couple metal flaps that make contact with the batteries, try prying it out a tiny bit so the connection is more secure and stops behaving erratically.
Jan 30, 2010 | Polaroid A530 Digital Camera
Clicking sound when ON button is pushed / Lens will not retract. Where can I send it for repair ??
Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (pand turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Oct 21, 2009 | Casio Exilim EX-S500 Digital Camera
My camera won't turn on
Take out the battery for like 10 minutes then put it back and turn it on.
It it doesnt work, then try putting a freshly charged battery on it.
Aug 31, 2009 | Nikon Coolpix 3200 Digital Camera
My camera won't turn on.
Try cleaning the battery contacts with a Q-tip and some denatured alcohol. Also clean the ones inside the battery compartment.
Aug 06, 2009 | Canon PowerShot S2 IS Digital Camera
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Kodak EasyShare C180 Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
