Question about GE DPSB613GDWW Gas Dryer
DRYER HEATS when started but doesnt continue heating although drum is still spinning after about 30 mins. you can restart and it heats up again on initial start up only
  • GE Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on Jun 12, 2011
Lgq9030pqo start dryer ,everything normal gas kicks on starts heating., heats for a couple of mins then cuts out doesnt come on again drum keeps on going everything else is normal
Typically - when this happens - the gas valve solenoid is failed, and needs replacement.
The flame sensor (thermocouple) may also be the culprit if it is failed - it will not tell the valve there is a flame present.
Check those out.
Thanks!
Aug 23, 2011 | Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
GE DPSB613GDWW Gas Dryer Logo
69 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
