Question about Goodman CLQ36AR49 Air Conditioner
GOODMAN HEATPUMP AC REVERSING VALVE MAKING A VERY LOUD BUZZING NOISE IN AC MODE. AC AND HEAT WORK FINE, NOISE ONLY WHEN AC IS ON AND UNIT NOT RUNNING.
  • 1 more comment
  • dencash4386 May 19, 2011
    THE UNIT IS NOT IN HEAT MODE. IT MAKES THIS NOISE IN AC MODE.
    THE AC CYCLES ON AND OFF NORMALLY, ITS ONLY WHEN THE UNIT IS
    NOT RUNNING THAT IT IS MAKING NOISE, UNTIL IT COMES BACK ON AGIAN
    SOMETIMES BUZZING ALL NIGHT.
    THIS IS A GOODMAN CPKJ60-1C AC
  • Vee Wafflez Jun 18, 2013
    only time ive seen heatpumps to get THAT loud is when its running too high of head pressure
  • Goodman Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. The reversing valve making noise (probably a 60 cycle noise) is a sign that the reversing valve is not stoking a full stroke to where the armature of the coil is neutralized by the internal plunger moving to the neutral position. Sometimes you can take 2 hammer handles to the BODY of the reversing valve with some careful strikes so as not to DENT the body and loosen up the internal piston so that it strokes fully. If that does not make it snap out of the buzzing routine then the only option is to replace the reversing valve. This will require the system to be drained of coolant, purged, the valve replaced and then the system recharged which does not come cheaply. It is not going to hurt anything buzzing. I know it is irritating and annoying but my thoughts are if you can give it some wooden taps and at least quiet it down some what to leave it alone unless your willing to go though the expense of a full system drain & service + a service call with a reversing valve change.
Here is the worst that can happen.... the solenoid on the reversing valve gets hot from not fully stroking and fails at which point you get the new reversing valve installed.
Thanks for choosing FixYa,
Kelly
Posted on May 20, 2011
    Genius:
  • 1,157 Answers
Hi dencash4386,
The buzzing noise that you're encountering is actually the running compressor. This is normal and part of the defrost cycle. During the defrost cycle the fan on the outdoor unit shuts off to keep the heat on the coils to defrost them. The humming of the compressor is covered by the air noise from the fan.
Hope it helps.
Thank you for using FixYa.
Posted on May 19, 2011
    Brigadier General:
  • 3,917 Answers
Hi
It sounds like it's just going through a defrost cycle.
The coils on the heat pump will be quite a bit colder than outside air when it's running in the heat mode, and it's normal for them to freeze up, which is why the defrost cycle is part of the design. It'll shut down the heat pump's fan and pump hot gas through the coils until the ice is gone.
When it's colder out, with snow and ice, there's not as much free moisture in the air to collect on the coils and freeze, so, typically, you won't have as much ice accumulation during colder temps.
It can also be caused by the compressor slugging a bit of liquid refrigerant that's condensed in the head. This can be harmful to a reciprocating compressor, but if your unit's only 6 months old, it's likely to have a scroll compressor, which is better able to handle a bit of liquid from time to time.
I'd say that it's nothing to worry too much about. If the noise really bothers you, you can ask the installer to install a sound deadening blanket over the compressor. They're relatively inexpensive and if properly installed can cut the noise down considerably.
Please check this helpful link to troubleshoot your problem when the heat pump is making noise:-
http://www.ductworkinstallation.com/NoiseReduction/HeatPumpNoise/tabid/274/Default.aspx
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Goodman Heat Pump laing heat and loud noise
Taking a little bit of time for heat is normal but the "pressure" thing you are referring to leads me to believe that the reversing valve is getting stuck. You will here that "pressure release" noise with a reversing valve but it should not be happening 5 minutes after start up.
May 06, 2017 | Goodman Heating & Cooling
Can not get Goodman 3-ton heat pump out of heat mode and into cooling mode
The reversing valve may be stuck. It allows the unit to switch between heating and cooling. You may be able to give it a tap but only on one of the ends, not the sides, and only lightly. You could also unplug the reversing valve from the circuit board. Some reversing valves are energized in heat mode some in A/C mode. When you unplug it, if it shifts, you will hear a loud hiss as the valve shifts and the pressure equalizes.
May 04, 2010 | Goodman CLQ36AR49 Air Conditioner
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
FAN ON COMPRESSOR SHUTS OFF
The loud buzzing noise if you have heat pump. May be comming from your reversing valve. To quiet this down. Turn off power to outside unit and squirt some oil into the reversing valve coil area. The coil slides onto a shaft this shaft has corroded a liitle and does not let the valve center itself. Alittle oil on the shaft help and quiets this down. DO REMOVE THE COIL WITH THE INSIDE AIR HANDLER POWER ON IF YOU HAVE POWER TO THE THE COIL AND REMOVE IT IT WILL BURN IT UP. yOU CAN JUST UNPLUG THE COIL IF YOU LIKE. RUSS
Jul 18, 2009 | Heating & Cooling
Heat Pump and fan work fine, but will not blow cold air on AC setting
The reversing valve coil may be bad or no power to it during cool. Most heatpumps are set to have the coil of the reversing valve energize in the cool mode. The heating mode is the fail safe mode if the rev valve fails to energize. Check this and let me know.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
Compressor noise
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Jan 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman Heat pump
GOODMAN HAS A PROBLEM WITH A FAULTY REVERSING VALVE. THEY IMPORT VALVE FROM CHINA AND ITS NOT GOOD QUALITY, THEY ARE IN PROCESS OF CHANGING VENDOR.
Nov 26, 2007 | Heating & Cooling
Goodman ac / heat pump
I just had a new unit installed and I am surfing for troubleshooting tips too. My unit is doing the same... cools well heat sucks. my problem has been isolated down to the reversing valve... It is constantly energised which means it is constantly in a/c mode even when kicking on the heat strips... We disconnected a line at the thermostat and it is working well as a heater now. You may want to check yours to see if it is actually kicking over into to heat mode... -rob
Nov 25, 2007 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
1,328 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
