Question about Dryers
Elesi of my electric fan. thing is my e.fan got knocked off and hit the ground then cause of the times it got knocked down, the elesi broke into pieces. i tried to use mighty bonds to put them together. and it is a success. but this one part on my fan's elesi keeps on braking. what should i do?
samson-1
  • 153 Answers
SOURCE: Brake Lights Wont Go Off
The brake light switch is your problem. Can be found at any parts store.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 02, 2008
wd4ity
  • 4565 Answers
SOURCE: i have a 78 flh
You may not have the kicker gear on the inside of the clutch release housing timed right. The gear has a knob on it that has to be against the stop inside the housing when the kicker is all the way at the top. Also, you must have enough spring tension on the kicker return spring to hold the kicker up firmly. If you don't, the kicker will bounce up and down while riding down the road. Make sure you've got the spring wound up tight enough.
Good Luck
Steve
Posted on May 29, 2011
bigguy810
  • 448 Answers
SOURCE: I'm installing a fan/light, the
ive seen this before use the white and green hooked up to the power
the black is the ground
i no it sounds crazy but ill bet it works
i hope this helps you
bob
Posted on Jun 01, 2011
wentlanv
  • 710 Answers
Hi Clare,
The fan should be connected only to the switch wires. If the wire sets were previously connected, then you have a "switched outlet", in other words - an outlet that can be turned on and off by the switch. With too many things connected on that circuit, an overload would be created that would trip the breaker.
I would need to know if the wires were previously connected and if you have anything plugged into that outlet. What is the amperage of your ceiling fan and the circuit breaker?
Handie Andie
I was sewing with my CG590 singer machine and then my needle broke. So I put in a new needle, and now it seems like it is hitting something when it goes down. What could this be and how do I fix it?
If the needle hit something (which is usually what happens when the needle breaks), it could very well have knocked the machine out of time. You can try installing another needle (make sure it is installed facing the correct direction) and see if that changes things. If it continues to hit something, you can search the internet for web sites and videos discussing "sewing machine timing" or take it for service.
Nov 12, 2016 | Singer CG590 Mechanical Sewing Machine
We got Juki DDL8100E. Few days ago. when sewing, needle broke and since then our machine is making heavvy noise. Also, the Stitch adjuster knob is vibrating up and down. please help
check that a bit of the broken needle is not interfering with the bobbin case movement
if the breakage was hard enough it may have altered the needle / hook timing which will cause a knocking sound as well
Aug 20, 2016 | Juki Sewing Machines
Why is my engine making a knocking noise, could I possibly get a list of things that cause knocking? It's a 1995 Buick century special, four cylinder.
Many things could be the cause. Common ones are:
  1. Low oil level.
  2. Low oil pressure due to worn out oil pump.
  3. Connecting rod knock (part of piston assembly)
  4. "Piston Slap" - this occurs when the cylinder wall gets worn into a cone shape, wider at the base from the side-to-side motion of the piston over millions of cycles. The wear gets to the point where the piston skirt (bottom edge) hits the side of the cylinder wall as it hits the bottom of the stroke and begins moving upward. Eventually the skirt will break off and the engine will need rebuilding or overhaul.
  5. You could also have a simple valve tap, as you are not really defining knock, although valves usually are more of a ticking noise rather than a knock.
  6. If the knocking only occurs on acceleration, you could have what is known as "octane ping" from fuel that is too low in octane. Not likely with a four cylinder, but some really cheap gas grades are occasionally guilty of being less than advertised for octane.
  7. There are even a few transmission issues that can cause knocking, so make sure you narrow down the issues before diving in too deep.
Hope that helps!
Sep 16, 2015 | Buick Cars & Trucks
I have an elesis RA 500 it blows the slow blow fuse when i plug it in .any ideas what is wrong?
hi there,
it sounds like the internal transformer has gone.
It's not user replaceable and will require you to take to an electronics store to be repaired.
SAME THING RECENTLY HAPPEN WITH ONE OF MY BITS OF KIT ...... for heavens sake don't just keep changing the fuse time and time again.
Jan 07, 2011 | Alesis RA300 Amplifier
My suburban when i go down the rood and hit the gas the battery light comes on for about 10 to 30 sec . I replaced every thing that i can think of
Have alternator checked and look for loose ground wires sometimes under dash ground wire gets loose and causes all kinds of electrical issues or false readings of trouble lights.
May 09, 2010 | 1998 GMC Suburban
I have a 2000 Lincoln Towncar. The air-conditioner compressor broke and also broke that big belt. A guy that lives near replaced the compressor and belt but now nothing electric works!!!! whats wrong!!!!!...
He may have accidently knocked some wires loose during the install or when your belt flew off the pullies it hit some wires and broke them. Check for wire damage around the pullies.
Aug 21, 2009 | Lincoln Town Car Cars & Trucks
MY fan belt broke now the car won't start.
if ur fan belt broke n ur water pump is run by it look out knock senser usually controls ur injector pulse so yea it will not start crank too cam no
May 25, 2009 | 2000 Kia Sephia
Eninge knock with a known cam gear problems.
i had the same problem. had a knocking on the engine and let the vehicle sit until i had time to look for the problem. my unknowing mom took the car without permission and the car broke down on her. as it would turn out the upper timing guide rail broke off and damaged the cam gears and broke the upper timing chain along with damaging both the right and left lower chain guides, and the tensioner was also damaged. i would recommend that u inspect the lower chain to make sure that everything is good.
Apr 09, 2009 | 1999 Suzuki Vitara
1992 Pontiac Gran AM SE 53K Windows Speaker etc. Bad Ground??
you mentioned tht the quarter panel was hit before you owned it was the door hit also
if you think bout it small breaks in the wire from the accident could have got weather in them over time and cause there connections to corrode or deteroiate let an automotive electrical shop give it a look
Mar 04, 2009 | 1992 Pontiac Grand Am
Lg 1030hr excessive ping noise
COULD BE ALOT OF THINGS BUT MY FIRST GUESS IS THE FAN SCREWS THAT HOLD THE FAN MOTOR COULD BE LOOSE CAUSING IT TO RATTLE ON START UP OR SHUT DOWN BUT REALLY NOT MAKING TO MUCH NOISE AS THE UNIT IS RUNNING. CAN YOU DESCRIBE THE NOISE BETTER? IS IT SCRAPPING LIKE A SCRUB OR KNOCKING LIKE HIT HIT HIT HIT?
Nov 23, 2007 | Heating & Cooling
Dryers Logo
301 people viewed this question
Top Dryers Experts
