Question about Koolstop Stroller Pack
I need the piece that holds the brake lever in place (on the handle bar) when you want to park on the kool stop/kool stride double jogger where can i find it. It was the small round piece with a spring
How does the brake work?
there have been countless accidents where unattended strollers have run away causing ***** to the child
the idea that you have is to prevent that from happening if you fail to apply the wheel brake
to do anything to prevent ti from working as designed will result in legal charges being place on you in the event of a accident involving injury to the child
it is not intended as an incinvience to you but to ensure the child's safety when you are inattentive
May 17, 2017 | Schwinn 13-SC906A Free Wheeler - Red/Black...
Need stroller manual
Either call Kool Stop in Oregon and ask for the Kool Stride manual you need or download this online one which is similar...
http://ebookbrowse.com/kool-stop-kool-stride-sr-paramount-series-jogging-stroller-owners-manual-pdf-d359030674
Apr 10, 2012 | Baby Gear
I have a bugaboo cameleon, now out of warranty. When I go up or down a curb the handle bar height estends. The white plastic clips used to hold the handle bar in place don't basically. Is there anyway to...
The handle extension lever is held in by the pin it pivots on, cut the tip of a smaller size nail and use it to tap out the pin. There should be a rubber block and a matching steel shim under the lever. The lever pushes on the shim and the shim on to the rubber block jamming it against the handle. The steel shim is the usual problem. it slips out. Open the other side and use that shim to get a copy cut. A piece cut out of a tin can could work.
Dec 17, 2010 | Bugaboo Cameleon Jogger
The piece that you pull down to put the brakes on broke off, what can i do
Bugaboo don't sell parts for the frame only the complete frame. The frame would be around $400 in the US but would increase the resale value of your buggy by at least $300 as you'll have the latest red handle brake lever and levers instead of wing nuts on the handle extention. Your old frame would be worth around $50 on eBay to a buyer who has a brake lever but another kind of fault on their frame. Go to www.bugaboo.com to order as new frame.
Dec 05, 2010 | Bugaboo Cameleon Jogger
On the right side of my bugaboo cameleon;the break side the black piece where the white clips are to adjust the handle bar. From being mad taller or shorter is off and the sprang came out and the handle...
Nov 19, 2010 | Bugaboo Cameleon Jogger
Diagram for back brakes on a 1995 jeep cherokee sport
Brake Shoes REMOVAL & INSTALLATION Fig. 1: Use a brake cleaner to clean the brake surfaces 86749p23.jpg
Fig. 2: Using a brake tool, remove the return spring from the anchor pin 86749p24.jpg
Fig. 3: Remove the return spring and the adjuster cable guide 86749p25.jpg
Fig. 4: Remove the adjuster cable 86749p26.jpg
Fig. 5: Remove the shoe guide plate 86749p27.jpg
Fig. 6: Disengage the hold-down spring retainers from the hold-down pins 86749p28.jpg
Fig. 7: Remove the hold-down springs and pins 86749p29.jpg
Fig. 8: Pull the shoes apart and then . . . 86749p30.jpg
Fig. 9: . . . remove the parking brake strut and spring 86749p31.jpg
Fig. 10: Remove the shoes from the backing plate 86749p32.jpg
Fig. 11: Disengage the parking brake cable 86749p33.jpg
Fig. 12: Lubricate the shoe contact points — 10 inch drum brake backing plate shown 86749g41.gif
Fig. 13: Adjusting the gauge to fit the brake drum 86749g42.gif
Fig. 14: Adjust the brake shoes to fit the gauge 86749g43.gif
Fig. 15: Adjusting the drum brakes using a brake spoon 86749p35.jpg
CAUTION
Brake shoes may contain asbestos, which has been determined to be a cancer causing agent. Never clean the brake surfaces with compressed air! Avoid inhaling any dust from any brake surface! When cleaning brake surfaces, use a commercially available brake cleaning fluid. NOTE: A brake spring removal tool and a brake adjusting gauge are required for this procedure.
  1. Raise and support the vehicle safely with jackstands.
  2. If the brakes have never been serviced before, the drums will be held on the wheel studs with spring nuts. Remove the spring nuts and discard.
  3. Turn the adjustment starwheel so that the brake shoes are retracted from the brake drum and remove the brake drum.
  4. Install wheel cylinder clamps to retain the wheel cylinder pistons in place and prevent leakage of brake fluid while replacing the shoes.
  5. Remove the U-clip and washer securing the adjuster cable to the parking brake lever.
  6. Remove the adjuster cable, cable guide, adjuster lever and adjuster springs. Remove the return springs with a brake spring remover tool.
  7. Remove the hold-down retainers and springs, then remove the brake shoes. To install:
  8. Clean the backing plate with a brush or cloth. Place a dab of Lubriplate® on each spot where the brake shoes rub on the backing plate. NOTE: Always replace brake linings in axle sets. Never replace linings on one side or just on one wheel.
  9. Thoroughly clean and lubricate the adjuster cable guides, adjuster screw and pivot, parking brake lever and lever pivot pin with multi-purpose grease.
  10. Apply a thin coat of multi-purpose chassis lube to the mounting pads on the backing plate.
  11. Transfer the parking brake actuating lever to the new secondary shoe.
  12. Position the brake shoes on the backing plate, then install the hold-down springs and retainers. Don't forget to engage the parking brake lever with the cable.
  13. Install the parking brake actuating bar and spring between the parking brake lever and primary shoe.
  14. Install the self-adjusting cable, cable guide and upper return springs.
  15. Thoroughly clean the starwheel and lightly lubricate the threads with lithium based grease.
  16. Install the starwheel.
  17. Install the self-adjusting cam and lower spring. A big pair of locking pliers is good for this job.
  18. Check the surface of the brake shoes for any grease that may have gotten on them. If dirty, lightly clean with a piece of sandpaper.
  19. Adjust the brakes, install the brake drum and wheel. Lower the vehicle and test drive.
Aug 17, 2010 | Jeep Cherokee Cars & Trucks
Jogger part needed
www.buggypitstop.co.uk sell new and second hand spare parts fpr all make of pushchairs including Quinney
Oct 12, 2009 | Jeep Liberty Urban Terrain Jogger
I need a diagram of a 1969 vw handbrake lever I have the button spring and rod that goes into the lever but cant see what holds the rod and spring in place Thanks
You have to loosen the parking brake cables so you can pull the handle up as far as it will go. You may have to take the cables off the handle. When you do this if you look down from the front towards the pivot of the handle you'll see a small lever that can be turned, it has teeth on one end a like a flat ball on the other. Slide down the rod and use a screw driver to spin plate around so the flat ball end goes into the hook of the rod. So as you press the button it will move and unlock from the teeth on the gear that stays in place. Reattach your parking brake cables and adjust and the job will be done.
Oct 10, 2009 | Volkswagen Beetle Cars & Trucks
Koolstop Stroller Pack Logo
23 people viewed this question
Top Koolstop Baby Gear Experts
Dorel UK
Dorel UK
Are you a Koolstop Baby Gear Expert? Answer questions, earn points and help others
