Question about Schwinn Cycling
Need help putting batteries in my scooter - Schwinn Cycling
  • 2,334 Answers
What CAN'T you do?
Posted on May 19, 2011
Cannot remove battery pack from scooter.
This battery box attaches to the base platform with some very aggressive Velcro. The bottom of the box has a battery connector that mates up to the platform when the box is put on the scooter. The easiest method is to pull straight up on the battery box using the handle of the box. You will feel the Velcro release. Use 2 hands and wiggle it slightly. Some earlier versions had a battery box that actually locked into the base. This battery box required pulling out the flat release levers on both vertical sides of the box to release the battery box. I am going from memory on this.
If you need another technique, try removing the seat first and stand straight over the battery box. Bending your knees and grabbing with both hands pull the battery box handle straight up. It should release.
Before reinstalling vacuum and clean the platform and bottom of the box so that dirt is not keeping the surfaces from sliding easily.
Hope this helps.
Apr 08, 2014 | Pride New Mobility Legend 4 Wheel Scooter
PRIDE MOBILITY 3 WHEEL SCOOTER FAILS TO MOVE FORWARD OR BACK
Hi. This is just a thought but have you tried putting the batteries back on the scooter and putting a volt meter on the batteries to get a reading when the lever is pressed on the scooter. Batteries can display as being fully charged (+12 volts) but often fail under load, meaning that as soon as you press the lever, the voltage will drop right off. If this happens, it is more than likely that your batteries are to blame.
Hope this helps.
Jan 04, 2013 | Pride Mobility Products Health & Beauty
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
I have the Shoprider Delux scooter.I brought it second hand.I put in a new battery but its not holding the charge. I seem to have to charge it up before any trips out.When its fully charged and I go about...
Yvonne,
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
Mar 18, 2011 | Shoprider Sprinter XL4 Deluxe 4 Wheel...
Details of batteries ie type of batterie and batterie rating and number of batteries reqired
All scooters (or at least 99% of scooters) will run on 24 volts, therefore there is usually two 12 volt batteries needed to run the scooter. Unless the scooter is very old, these will be in the form of dry batteries (sealed top with no water top up required) usually GEL, SLA or AGM. It Doesn't matter which type you use but GEL tend to last a bit longer and are more expensive. As to which size of battery you require, it should be marked on the battery somewhere in an Ah rating, for example 12v/31Ah. I would need to know which model of scooter you have to be able to help you with the size you require. You should also replace batteries in pairs, not as a single and should use the same rating and type, so dont put 31Ah batteries with 36Ah batteries and not an AGM with an SLA, GEL etc. Hope this helps...
Mar 11, 2010 | Health & Beauty
Very slow go go scooter
hi, Sorry but those scooters are not stable at higher speeds,
the controller and battery fitted to those scooters cannot be made to give more power hence more speed, there is a number of reasons, the motor draws power from the controller and the controller gets what it requires from the battery, if you put on higher amps batteries , the scooter will go further not faster,
you would need to upgrade the motor to make it go faster, now the controllers are norrmally overrated so it could handle the extra power required, I would say it's impossible to upgrade the motor.
So another mobility scooter would be required,.
Don't get me wrong, there are lite scooters that go 8mph , I think TGA do one.
Regards
GeWiz.
Jan 16, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Oct 29, 2009 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
Nov 25, 2008 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Electric scooter Troubleshooting
A small tip here - bigger is better. The large diameter wheels clear gaps in concrete or pavement that would hang up a skate wheel or a scooter with smaller wheels. Most electric scooters also handle well in gravel and small terrain features. We don't recommend slamming electric scooters into a curb to get over it like some people do with their bike. This could result in damage to the electric scooter. Simply Ollie up a curb and keep going.
Aug 27, 2008 | Drive Medical Mini Phantom Three Wheel...
Cycling Logo
21 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
