What does the flashing LD mean on a whirlpool cabrio toploader?
  • 110 Answers
It is signalling a pump/drain issue.
More info on codes for the Cabrio:
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
Posted on May 19, 2011
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Wondering what code F-- means on cabrio whirlpool topload mod. wtw66005w2 Thank You
Is there a number after the F code?
Thats ok heres what the code means: Whirlpool Cabrio Washer Fault Codes.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Hope helps.
Aug 03, 2011 | Washing Machines
Flashing Ld on display
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Cabrio Manual
More topslosher failure codes and explanations are HERE
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't drain. Keeps flashing LD
LD means long drain time need to pull pump and clear.
If that doent work replace pump
Oct 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does error code LD mean?
"Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back thank you again and have a nice day
rickead1
Aug 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Get message LD. Won't drain. Removed clothes from washer but still won't go into drain mode.
Ur drain pump needs to be replaced. I just had this same issue with my whirlpool cabrio.LD means long drain.
Aug 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code
taking too long to drain,there is somthing in the drain pump intake or the drain hose is kinked. there could be somthing in the pressure switch hose makeing it think it still has water in it
Dec 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My Whirlpool Cabrio (WTW6600SW1) drains completely then Ld error!
I have a call with the same problem. Pumps all the water out but still flashes LD. Should be the board, The electronic pressure switch is built in to the board. Make sure the pressure chamber on the back right side is not cloged
Aug 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer Problem
cabiros dont have a wig wag switch check your drain pump for obstructions to find the right repairman go to www.whirlpool.com under support enter your zip code under find a service tech and they will give you a list of people in your area
Jul 07, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
