Question about Garden
My house is wired thru a 120v photocell for the exterior lights. It will not turn off and the lens is clean. There is no wall box behind it. There is just a small black photocell in the exterior stucco. Will this unscrew and is it replaceable? I am wondering if I can just unscrew it and take it to Lowe's or something like that to get a replacement.
  • 927 Answers
If you can't remove or replace that photocell, you can bypass it. Since the lights stay on, you could locate the circuit elsewhere and wire into that location another photocell or timer or both.
Gary
Posted on May 19, 2011
When could I get an answer to my question
Have you tried contacting the manufacturer?
Oct 05, 2015 | Home
My son bought a new house. It has an Intermatic K4221 photo cell that never appears to work. It looks like it is connected to porch lights. They won't come on either by photocell or manual light switch. He...
Place tape over photocell lens, and flash switch off-on. Did the light come on?If you know how - remove the photocell from the circuit and see if the light works. If the light works, then the photocell is probably bad. Check power from switch to photocell with test meter.
May 17, 2014 | Intermatic K4221C Photo Cell Control 120 V...
I have a problem, I want to add a photocell to a light, here is the setup, there is a capacitor with 2 wires coming from it, one is free, the other goes to the ballast, then 3 wires on the ballast, to hook...
1) Photocell needs to be wired on incoming power line.
The photocell is a switch, and the switch is powered by incoming voltage... 120V, 240V, 277V, etc.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
2) Add comment and describe voltage and how the light is powered.
Feb 18, 2013 | Electrical Supplies
How do you connect a photo cell to a 220v HID fixture?
You can connect photo eye white wire to ground wire, and it will work, since each hot wire in 240V circuit carries 110V to ground.
But this installation is not code.
It is not necessarily dangerous if you are only person working on electric circuits, and you remember what you did, and don't work inside main box without turning off power.
See illustrations.
Running a White neutral wire from nearby outlet is best solution.
Or buy 240Volt photo eye.
Oct 12, 2012 | Cooper Wiring Devices 1301-7LTWBOX LIGHTED...
The lights do not go off ?? Is it a bad photocell? They are on all day..and night..
Photocells go bad.
If photocell was working before and stopped working, then photocell is bad.
If photocell never worked, then check wiring.
I buy cheap 120Volt photocells at home center, and when they go bad, buy same brand again, and return bad one in new package if bad one still looks new.
Intermatic has 120V and 240V photocells.
Open following link for Intermatic resources and ez photocell wiring diagram
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#photo
Apr 21, 2011 | Intermatic K4221C Photo Cell Control 120 V...
Wireing diagram do not no were thay go three wires
K4221C photo cell page at Intermatic:
http://www.intermatic.com/products/photo%20controls/commercial%20%20industrial/stem%20%20swivel%20mount%20-%20thermal%20type.aspx
Photocell has black, white and red wires on photocell.
Black goes to Hot from breaker.
White goes to Neutral from breaker box
Red goes to Load (light)
Electricians don't guess, they test.
You should have one wire coming from breaker box, and another set of wires going to light.
Separate wires for testing.
Since you are outdoors, stand on dry boards and tape tester leads to wood sticks to keep hands away from power.
Turn power ON
Test each wire to bare ground wire.
Tester lights up on hot wire. This wire should be black.
Hot wire connects to photocell black
Hot is identified.
Test Hot wire to all wires except bare ground.
Tester lights up on neutral. This wire should be white.
Neutral wire connects to photocell white
Now the other cable goes to Load. This cable has a black and white wire.
Connect photocell red to black Load wire
Connect white Load wire to Neutral, along with photocell white.
Ground wires are twisted together.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 11, 2011 | Intermatic K4221C Photo Cell Control 120 V...
I have a Tork timer model number 1101 24 hr time switch. Can you tell me how to set it???
Tork 1101 is a 120V mechanical dial-type timer
c79f9b8.jpgTork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
Oct 14, 2010 | TORK 651A Photocell Controlled Mechanical...
Which fuse controls auto lamp feature in 2002 Ford F350?
Principles of Operation
The autolamp system provides light-sensitive automatic on/off control of the headlamps and parking lamps controlled by the vehicle security module when the headlamp switch is in the autolamps position. When the ignition switch is turned to the RUN or START position with the autolamps feature already enabled and the ambient light level is dark, the vehicle security module will request the headlamps and parking lamps be turned on. When the autolamps are disabled, the vehicle security module will request the headlamps and parking lamps to be turned off, regardless of the ignition switch position. When the vehicle security module has turned on the exterior lamps and the ignition is turned to the OFF or ACCY position, the exterior lamps will remain on for an additional 20 seconds.
When the autolamps have been enabled and the ignition switch is in the RUN/START position, the vehicle security module will request that the exterior lamps be turned on or off based on ambient light level. If the vehicle enters darkness for at least 15 seconds, the vehicle security module will request the exterior lamps on. If the vehicle enters light for at least 15 seconds, the vehicle security module will request the exterior lamps off. By delaying turning on and off the exterior lamps during short periods of darkness and light, the vehicle security module prevents the exterior lamps from flashing on and off.
Inspection and Verification
  1. Verify the customer concern by operating the autolamps.
  1. Visually inspect the following for obvious signs of mechanical and electrical damage.
    Visual Inspection Chart Mechanical Electrical
    • Headlamp switch
    • Central junction box (CJB) fuses:
      • 19 (5A)
      • 56 (30A)
    • Circuitry
    • Headlamp bulb
    • Daytime running lamps (DRL) full relay No.1 (if equipped)
    • Vehicle security module
    • Photocell
  1. If the concern is not visually evident, determine the symptom and proceed to the Symptom Chart.
  • The autolamps are inoperative—do not operate correctly
  • Central junction box (CJB) fuse(s):
    • 19 (5A).
    • 56 (30A).
  • Circuitry.
  • Photocell.
  • Headlamp switch.
  • Vehicle security module.
    • 19 (5A).
    • 56 (30A).
  • Circuitry.
  • Photocell.
  • Headlamp switch.
please rate if if this helps.
Apr 29, 2009 | 2002 Ford F350 Super Duty DRW Reg. Cab
Photoelectric Control (Photo Eye), dawn to dusk, install
Connectthe SUPPLY wire (Black) to the Photoelectric Black. ALL of the white wires - to lights and from supply and on PE - connect together
Redfrom PE goes to all light fixture black lines
Nov 24, 2008 | Electrical Supplies
Kenmore 110.72512101 gas dryer
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
