Question about Admiral Refrigerators
Unable to look up this model # HMG191240. Top frez. Need def. heater and bi metal thermo.
  • Admiral Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on May 20, 2011
Hotpoint frige/freezer mod stf 200 wp keeps freezing up
Need exact whole model # for more info.
sound like a defrost problem .
Defrost Bi metal or defrost heater bad and the wurst main computer board. Ice builds up on back wall of freezer.
thaw back wall remove panel heater will be at bottom of coil Bi metal will be at top of coil small disc shape thing with 2 wires coming out
check both . bi metal must be tested cold at 30 degree opens at 35 degree if never closes then there is your problem
Mar 07, 2015 | Hotpoint Refrigerators
Freezer is working and slightly over freezing, but fridge is not working
check air flow. if fan not running replace fan if running but lots of frost on back wall then its a defrost problem (when it doesnt defrost ice builds up blocking air flow to refrig side.) try forcing into defrost if it has timer or ck bimetal (bi metal most common) (on ge fan not common but def heater is). post model for more help
Sep 14, 2012 | Refrigerators
Ice forming on back wall of freezer, not making ice, not getting air flow to refrigerator
Thaw out the evaporator and check your defrost heater for continuity. Check you bi-metal thermostat for signs of swelling. The bi-metal has to be @25f before continuity can be confirmed on it.5051637.jpg Check your defrost timer or adaptive defrost control if the heater and bi-metal check out. Notice the bi_metal mounted upper right hand corner. It opens and kills the heater once the temp gets hot enough to melt the frost.(50f)
Jun 01, 2010 | Kenmore 64802 Top Freezer Refrigerator
I am having trouble with it will be working fine for about a week then it will just kick off
sounds like the bi- metal thermo-stat switch puts in a week, then takes a little time off,now what's the matter with that, replace switch or if you're mechanically inclined you could clean and recalibrate the bi-metal switch
Jan 30, 2010 | Heating & Cooling
I'm getting frost in my freezer and loosing temperature in my frig
Hi, Unplug the refrigerator. The automatic defrost is not working properly. You will need to remove the rear panel inside the freezer section and test the defrost heater and bi-metal switch. The bi-metal switch located on the top of the evaporator coil needs to be tested while it is still cold. Check and see if the switch has continuity. If the bi-metal switch shows an open circuit, replace it. If it shows a closed circuit, test the defrost heater the same way. If both the defrost heater and the bi-metal switch are ok, the defrost timer will need changed.
You will need to defrost the evaporator coils with a hair dryer. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Aug 14, 2009 | Refrigerators
GE Model TFX20D not cooling!
Hi, If the defrost heater doesn't come on, check continuity on the bi-metal swtch located on the top of the evaporator coil. The bi-metal needs to be cold when testing it. If the switch is cold and shows an open circuit, it will need replaced. The bi-metal switch is a thermostat that turns the defrost heaters off when the desired tempurature is reached,.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
2001 top freezer won't defrost
Hi, You will need to check three different parts of the defrost cycle. The most common problem is the bi-metal switch. UNPLUG the refrigerator and remove the rear inside freezer panel and locate the bi-metal switch attached to the evaporator coil in the upper corner. You will need a voltage/ohms meter for this test. Check the switch to see if it has continuity. Note: This switch has to be cold in order to test it! If it tests open circuit, you will need to change the bi-metal switch. If the bi-metal switch tests ok, then test the defrost heater the same as you tested the bi-metal switch.
IIf both of these parts test ok, you will need to change the defrost timer.
Please get em a model # and I can assist you on locating the timer.
Vic
May 29, 2009 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool Freezer
Most likely you have a defrost problem. IF, you think the timer is ok then the most likely problem is the bi-metal. That is a little part usually on the top right side of the evap coil and has two wires on it. If you can find the defrost timer and advance it slowly till the refrigerator stops running, then being in the defrost postion you can see if the heater is coming on. If so you have a bad timer. If NOT, then either the heater or the bi-metal is bad. Usually it is the bi-metal
Aug 27, 2008 | Freezers
Crosley refridgerator
the only probable cause why a freezer compartment will be hot is if the heater coil that used to heat the ice is still running even there are no more ice in the evaporator.
that will only happen if the bi-metal or thermo disc is shorted.
bi metal is a part where in it would open at 4 degress celcius in order for the defrost heater to stop heating. but if it is shorted then even though the evap temp is more than 4 degrees celcius, it is still heating up ang would make the freezer compart,ment hot.
i hope i answered your problems...
pls rate e..
tnx
drcool
Jul 18, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
69 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
