Question about Insignia NS- 27" TV27 TV
Wierdness with the TV
If it is plugged in at all, it turns off and on by itself every 3 seconds, tried different jacks, de-batteried the remote just in case, checked to see if the on/off button was stuck. nothing. I dont have the $ to buy a new tv, so I am hoping to avoid chucking it in the garbage, can you help?
    Scholar:
  • 59 Answers
OK - the bad news - like most electronic gadgets these days your TV when plugged in sits in a state where its using electricity waiting for you to push the remote button such that it can jump into life.
This means that there is a circuit in the TV that specifically energises when you push the remote on button and that kicks in a transistor to energise a relay that turns on the juice to get the TV going. Sounds like there is something in that energising circuit that has broken down, perhaps a resistor that is not a resistive as it used to be or a capacitor that is leaky and as a result the circuit is performing the signal to turn the relay on and loosing the capacity to keep the main power relay energised and then the relay is turning off, until the capacitor recharges and it is re energising the main power relay again.
The problem here is that there is no way that you are going to find that faulty component on your own without a wiring diagram, and oscilloscope and a knowledge of electronic design.
You could look up in the yellow pages TV repair and talk to some one over the phone to get an understanding of what may be the problem and a guideline on what they think it may cost to repair. It shouldn't be too much but if they give you the story of lots of dollars you could ask how much to just solder the relay such that the TV comes on straight away when you plug it in rather than having to use the push button or remote to turn it on.
It by passes that circuit - its a little more harsh on the electrics and it means you have to plug and unplug the set to turn it off and on but its an option if you can't afford a new one.
Sorry I can't be more helpful. Good Luck
Posted on Aug 14, 2008
WE JUST BOUGHT ROKU , HOOKED IT UP , CAN'T GET ANYTHING ELSE TO COME UP
You must match the TV's input connections and the Roku output on your remote. This means if the Roku's output is connected to your TV's "HDMI 2" (or A/V 2, etc.), you must be able to select HDMI 2 (or A/V 2, etc) on the TV - either with your remote or pressing a button on the TV itself.
Sometimes, the TV will skip over unused inputs when it was first set up. This is done to reduce the number of button presses to go from say "HDMI 1" to "HDMI 4" by programming OUT the HDMI 2 & HDMI 3 choices.
You'll need to program IN the input that your TV uses to connect the Roku if it isn't already available. You MUST connect cables properly if not using HDMI. RGB is Red-Green-Blue and must be connected to RGB jacks at the Roku and TV for a picture and the the White & Red (left and right) audio must connect the the corresponding Red / White audio jacks - or it will provide strange results.
Make sure the power plug is connected to an outlet that is ON and connected to the power jack on the Roku box itself. Unless you have a defective Roku box or TV, it SHOULD work. You can try using a different HDMI or A/V jacks on the TV to determine if it is the TV jacks or not.
Sep 10, 2013 | Televison & Video
I have a UMC TV /DVD Combi the remote control i got with it no longer turns the TV on or off, so i bought a universal remote and it cant seem to find the code for the remote so i was wondering would anyone...
First of all, did you put new batteries in the remote control?
That usually solves the problem, because when the batteries get weak
the output infrared signal also gets weak.
With a new universal remote control, there is a booklet containing the
codes to use for many different TV receivers. If your specific TV model
is not listed, try using one that appears to be similar to it. If that does
not work, try turning your TV on with the new universal remote. If you
can turn it on, then you may be able to have the universal remote
program itself by interacting with your TV. Turn it on and hold the
remote so that it points to the TV set and hold it there for about 30
seconds. Then try turning the TV off and on again and try to use
the channel change feature. Try this a few times to give the TV and
the remote a chance to talk to each other. Keep the remote pointed
toward the TV.
Aug 29, 2011 | Televison & Video
Hi my son got a 19inch emerson tv for his 2nd birthday and now anytime it gets plugged in it flashes different colors and the buttons does't work and the only way to turn it off is to unplug it!! can this...
Press the the cursor key up followed by down and power the TV off with the remote or the TV itself. Please use the original remote for this. Unplug the TV for a few seconds...replug and power the TV on. The second thing to try...press the cursor key left followed by the right key. Power the the TV off with the remote or the TV itself. Unplug for a few seconds...replug and power up the TV. Some of these TVs left the factory in the service mode. The fix is pretty simple. Thanks asking and show a few hands of support!
Feb 14, 2011 | Emerson LC195EM9 19 in. LCD TV
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
Remotes will not work
change sensor of your remote control ,if there is not solve than change your sensor of your tv
Jun 02, 2010 | LG 42PG20 42 in. Plasma HDTV
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
I can turn my wii unit on with the remote, but cant turn it off with the remote. also I get nothing on the tv screen when I turn it on. we just got the unit today and I know nothing about it
Try switching the cables connected to the TV to your Wii, plug those 3 pronged cords into a different side. And about the remote thing, Im not 100% sure but i think you might have to open the battery compartment and press the red button to sync with the Wii.
Jan 10, 2010 | Nintendo Wii Console
How do I replace the IR remote sensor on my LG TV?
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
Jul 08, 2009 | LG 42LC2D 42 in. LCD HDTV
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
Insignia NS- 27" TV27 TV Logo
379 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
