Question about Bosch SHE43P16UC Builtin Dishwasher
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
  • 110 Answers
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
Posted on May 19, 2011
Hi, i have a bosch classixx5 washing machine(1400) , it's going through it's cycles until it tries to drain & then nothing, it won't drain... Please could you offer suggestions & s
You first of all need to check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and junk. The pump itself is directly behind the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
Mar 17, 2013 | Bosch Washing Machines
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Kind Regards
JEDEMEYER1
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Maxx Classic WAE20261AU/01 front loader. The machine won't start because the door won't lock. The door has been playing up a bit for about 2 months, but now it won't lock at all. It is...
Sorry. It seems that I have fixed it by using your solutions!
I drained it and cleaned the filter thing down in the bottom right hand corner, put it back to gather and then it turned on again!
Interestingly I found a bobby pin down there!
Thanks for your assistance John_Cross!!
Jun 21, 2011 | Bosch Washing Machines
Our bosch washing machine is about 9 years old and won't drain properly. The "end" light flashes as if the drain is blocked but it's not. If we manually drain the machine we can get onto...
As you do not mention 'filter' I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 05, 2011 | Bosch Washing Machines
Currently own bosch exxcel washer 1400 about 4 years old had some new brushes replaced about 4 month ago by local eng,washer currently not going throuugh any cycle won't spin or drain just counts down...
(no promises but try this if you haven't already!)
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
John C
May 12, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch SHE45M - Drain problem
Hi..
please check whether you have something in the drainpump locking it up or a blockage somewhere between the sink and the unit or the pump itself has failed or not.
thanks
May 04, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHE43P16UC Builtin Dishwasher Logo
215 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
