Question about Computer Gear Rubik's TouchCube
I got a touch cube i hit the all the resets but when i go to charge the thing it wont charge iget the red light on the base likes it charging but every time i put it on the base or try turing it on it flashes red and makes a noise i have just sitting in the box for a year without playing it how come it wont charge i let it charge during the night and also the day but never seeing the green light
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
I just received a brand new v-touch fresh out of the package, and it will not turn on.
Hit the "reset" button on the back, lower right. Even if the player is off it will still reset the V-Touch. If this does not work I would highly recommend sending Visual Land a email on how to fix this issue. You can contact them here: http://www.visual-land.com/support_form.html
Jan 23, 2012 | Visual Land V-Touch Digital Media Player
My g1 wont turn on when i try to hit the power button the top light turns blue and when i do the reset it dose the same thing
Is the battery charged? Is the charging LED showing up as normal when you connect the charger? Try charging the battery for a few hours and then try to reset the device?
May 04, 2010 | HTC G1
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Stevie
Feb 14, 2010 | Uniden Cordless Phone
Palm cantro keeps hot syncing can not use my phone
this has also happened to mine like yesterday, dont remove the battery mine wont turn back on now, try letting it charge overnight withoout touching it at all
Oct 23, 2009 | Palm Treo 500 Centro
It won't turn on! I charge it, and the camera is no more than a year old, and yet it wont turn on. However, when it's on it's base, it can connect to my computer and turn on fine! Is it the battery?! Why...
Mine won't turn on...unless I hit the red button, then the menu button, then repeat...the red, then the menu. When the menu comes up, it wants to reset the date/time etc. I just ignore that and hit the menu button once more and it's ready to shoot. Pain in the you know what.
No more Casio cameras.
Jun 26, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Handset cannot get charge from base
If you have the base unit plugged into an outlet that is drawing a lot of current, then the battery won't be able to get enough current to charge the battery. Plug it into an outlet that doesn't have a lot heavy current use. Televisions, refrigerators, microwave ovens, etc do draw a rather heavy current when in use. Things like a radio, lights, etc don't draw that much. Also make sure that you place the phone on the charger so that the contacts touch. Then the red "charge" light should come on and you will be in business.
Nov 18, 2007 | GE 25932 Cordless Phone
Computer Gear Rubik's TouchCube Logo
122 people viewed this question
Top Computer Gear Toys Experts
ray gallant
Are you a Computer Gear Toy Expert? Answer questions, earn points and help others
