I moved and had to disconnect everything i lost my cd to my printer.. how can i connect it again for it to be wireless?
  • 63 Answers
Typically you can go to the manufacturer's web site and download the driver software, since you have not included any details regarding the printer, it is impossible to know where to direct you.
For example if you have an HP printer, try http://www8.hp.com/us/en/support-drivers.html
Hope this helps, if not, please include the make and model of the printer in question and we'll get you to the right page
Posted on May 19, 2011
Canon IR 2520 lost IP address
This is regular feature. Nothing defective here.
IP address is to communicate with the router on wire or wireless.
Dynamic IP address will assigned to your printer again when re-connected and will be lost when disconnected.
Static IP address assigned will be reserved at the router for the device even when the device is disconnected.
Apr 18, 2016 | Canon Office Equipment & Supplies
I dont have the cd for the printer and I dont know where to start to correctly install it for LAN printing. It worked before but I changed routers when I moved.
this is the link where you can download the software to set up your printer again on your new router. under the software link, choose the link that says "Canon PIXMA Wireless Setup Assistant (Windows)"
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp495#DriversAndSoftware
Nov 11, 2012 | Canon PIXMA MP495 InkJet Printer
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Wireless-G WRT54G Router: I lost internet connection from router. Everythin...
Unplug both router and modem. Disconnect modem from router. Wait 5 mins and reconnect everything.
May 18, 2010 | Linksys Wireless-G WRT54G Router
Wireless working but not connect to internet
Shut down everything. Modem Router and pc.
Turn modem on and wait for it to sync with ISP (1-2 mins)
Turn on router and wait for it to sync with modem (1-2) mins
Turn on PC.
It sound like your Router and Modem lost sync with each other. You must wait until devices sync and you must do in in the order listed.
Jun 08, 2009 | Dell TrueMobile 1184 Wireless Broadband...
How to hook up this printer wireless to my main computer
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Feb 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Wireless communication to printer from pc is lost
You may be having an issue with an usb hub try connecting it to another usb port. If this is a notebook and you are connecting it through a port replicator disconnecting the notebook from the replicator can cause you to loose connection to the printers.
Jan 14, 2009 | Dell Dimension 8200 PC Desktop
My HP 1610 printer works, the copier works but when I try to scan it says "No scan options" need to install or run device software. Don't have the disk we had a flood 9/14/08 and everything lost in the...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printing through wireless
hi,
if you had the printer before using the USB cable. then you changed it to wireless, try the ff:
1. re-insert the CD the came with the box, the cd that you used to install the printer Software to your computer.
2. after inserting the cd, it will give you option "add a device".
3. click on that to install the printer driver for WIRELESS.
note: the reason why you cant print, is mainly because the printer driver you have is still for USB connection. so inorder for you to be able to print, you need to install a printer DRIVER for wireless... That should WORK..
adonscott
HP TECH
Jun 23, 2008 | HP Officejet 5610 All-In-One InkJet...
11 people viewed this question
jasbo
jasbo
