Question about Uniden Cordless Phone
Phone flashing 88 8 now flashing e4 cannot get dial tone.
  • 3,083 Answers
Your manual may have the E4 code, but Uniden certainly will, if you contact their support site. This symptom often indicates a power or function issue with the base unit, and so make sure the base has charging voltage, and the terminals are clean (use a qtip and alcohol). When you contact Uniden Support, have your model number ready, since different units can have the same or different error codes programmed into them.
Good luck, and hope this helps.
Posted on May 19, 2011
Uniden phone light WON'T flash red light when I have pulsing dial tone VM messages.
The pulsing dial tone usually indicates a message on the service provider's server, not on your phone. Contact your provider to find the procedure to access these messages.
Aug 15, 2016 | Uniden Lands Phones
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
Base reads e4
Base unit display flashing "8" and "88" repeatedly and then after several minuteseventually displays "E4" steadily. none of the keypad inputs register - unit is basically non funtioning with the exception of the display. no dial tone on base unit or on any of the handhelds. Manuall trouble shooting guide has no suggestions for this conditions nor does it contain any error code definitions. Have unplugger and replugged unit power source (to see if it would possibly reset) with same results. Would appreciate any assistance or suggestions you could offer.
Thank you.
Jan 05, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
No dial tone. No calls. Can't call out.
E4 IS AN ERROR MESSAGE, THE BASE IS NO LONGER GOING TO WORK, POSSIBLY A POWER OUTAGE COULD OF DAMAGED THE BASE.
Dec 28, 2008 | Uniden Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
Dec 06, 2007 | GEH5450 Cordless Phone
Radio Shack 43-3880 5.8GHz digital answering system - error codes
Well, bad news! After taking my phone to Radio Shack and allowing them about 30 min. to identify the issue, the result was that an E4 error means a non-repairable internal problem. If the phone is less than a year old, and you have a receipt, it is covered by warranty.
Oct 29, 2007 | Lands Phones
Uniden Cordless Phone Logo
1,306 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
