SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write. You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you. What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving. During the wash cycle, the top half is just sitting still. If this is wrong, please let me know. If this is right, you have a sort of simple fix. Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off. When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there. You can put your finger on the lips and lift it straight off. Then you will see a cap with a bolt in the center. Remove this bolt (7/16" with long extension). the agitator dogs (Sears part #387091) . You should see these under that last cap tha had the bolt in it. Remove the auger (just slide it up and off), remove the dog holding cap. Remove the dogs, but be sure you remember the way they go back in. Next is the tricky part. Take the cap upside-down, and place it back in the auger. Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole. Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator. Make sure the locks and stuff fit right between the two. Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap). If all goes well and right, you should be able to roll the auger one way and not the other. If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along. Good Luck!!!!! Jim
SOURCE: Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Thanks! Removed the fabric softener dispenser, then the plastic cap with the raised plastic strip, inside the post by reaching in and twisting until the o-ring seal becomes free, then removed the bolt using a 7/16" socket with a long extension. Walked in the washer supply store with the whole module that holds the dogs and the man at the counter saw it in my hand, reached under the counter, laid the 4 plastic dogs on the counter without me saying a word and said "that all you need?" think they sell a lot of them? part number fsp-80040. repaired in 40 min.s including the 5 mile trip to the parts store!
Donna K.
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
SOURCE: clothes stuck under the agitator
The clothes do not go under the plate they spin out of the top and fall over the side, this is because socks and underwear are either overloaded or spun out, this can be solved by reducing the load size and also spinning small clothing items on lower speeds, but the solution above is very helpful for getting the clothes out, but you will need a long pair of needle nose pliars to pull the clother out of the bottom of the tub. This problem presented itself by a "LD" error (long drain) Thanks tzweeb and I hope this helps others
