Question about Nintendo Wii Console
I just recently move my entertainment center around and plug all of including the Wii console. so when i put everything back, plug them all in the Wii console did not work... I thought i meight have shorten out the power cord could that be true
  • 24 Answers
It's very possible. If you plug in the power source for you Wii and no light comes on at the power button for the Wii, it is a problem with the power cord. If not, it may be a problem with the Wii itself. Test this out to see whether you need to get a new power cord or to have you Wii sent in for repair.
Posted on May 19, 2011
When i plug either of my gamecube controllers into the 1st port on my wii, they only move side to side not front to back
Hard trying to fix game cube controllers specifically because i don't think Nintendo really sells game cube controllers anymore. But try to plug it back in and fourth. I usually really go tough and move the joystick around, works for me, you can try doing that if it doesn't work you might have to buy a new one.
Mar 04, 2013 | Nintendo Wii Console
Is it ok to have a cluttered media center?
Of course it is ok to have a cluttered media or entertainmentcenter. The key is to make sure that theclutter is only made up of things that you use on a regular basis. If you play Nintendo Wii once every 3 years,it would be better off if you put it away in a nearby drawer, instead ofgathering dust on the display. The otherimportant thing to do is make sure that the clutter is organized. Everything in your entertainment centershould have a set place, with everything facing outward and evenly spaced.
May 29, 2012 | Furniture
I recently moved and am not sure how I re-connect the Wii to the tv. HELP!
Make sure you have the following, Your Wii system, your TV router (The red, yellow, and white plugs), And the charger. When you set up your Wii, Connect the red, white, and yellow plugs to the correct sockets on the side or the back of your TV. Once you do that, Turn on your Wii, Press Input on your tv, And it should bring you to AV2 or something similar, and theres your Wii.
Jun 03, 2011 | Nintendo Wii Console
What is error code 51031
Error Code: 51031
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • Check for interference that may be preventing a successful connection:
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
  • Check to see if the router you are using is a known to be incompatible. Click here to view the list. If your router is known to be incompatible, you'll need to use a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
  1. Login to your router's settings (click here and select your router, if available, for information).
  2. Look for the section for SSID (typically in the "wireless settings" area).
  3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in the list of wireless routers, and check for any special notes that may be necessary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufacturer's website; consult the manufacturer for more information.
May 10, 2011 | Nintendo Wii Console
Wont read disc
sure, but wii dvd drive is very hard to adjust laser and calibration fixes...it´s very sensitive, you must search for youtube to see calibrating videos for Wii....take a look in the motherboard to see if there is any chip or components loose inside the wii...Good Luck!!!
Sep 09, 2009 | Nintendo Wii Console
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Wii My Wii powers off everytime I put in a game disc
I had the same situation. I solved it by making sure the grey power cord for the wii was plugged in right and that it was plugged into a transformer. In the end the problem was that the wii was just not getting enough power. It doesn't exactly explain why the wii turned off every time I put a game in but at least I got the wii to work.
Oct 29, 2008 | Nintendo Wii Console
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Nintendo wii
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Oct 04, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
