Question about D-Link DWA-556 (ASKU58510) Wireless Adapter
I installed the DWA556 adapter in my new HP6050z computer and used the D-link CD to setup the connection. Worked fine. But then I turned off the computer and when I rebooted, I get the Windows blue screen immediately. I'm using Win 7. When I talked with the support person at D-link he said it appears that the adapter is not compatible with the HP motherboard.
    Novelist:
  • 123 Answers
Good day. In regards to your issue, if the d-link support agent told you already that its not compatible with your hp motherboard, you might consider getting a new wireless adapter. Better you can contact d-link again and ask them about a model of wireless adapter that will work fine with your HP computer. Its better to replace your wireless adapter than putting your entire computer in jeopardy. Conflicting hardware might cause instability and might crash your entire system
Hope this help you a bit. Have a great day and thanks for using Fixya. :)
Posted on May 19, 2011
I have windows 7 and my d-link PCI adapter is not working. the LED is not on and i cant connect, or even see, any wireless networks and windows 7 says my wireless is disabled. I've tried using the CD...
Hello
You might want to try the latest drivers from the main dlink homepage. I took me the liberty to find them for you.
ftp://ftp.dlink.com/Wireless/dwa556/Drivers/dwa556_drivers_140.zip
You press that link and download it. It's in a zip compressed format. So unless windows can unpack it for you after opening it you will need a decompressing tool like WinZip or WinRar
Once you've downloaded it you can follow this quick guide.
ftp://ftp.dlink.com/Wireless/dwa556/QIG/dwa556_QIG_140.zip
Good Luck! If you still need a hand just post here again.
May 14, 2011 | D-Link DWA-556 (ASKU58510) Wireless...
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
I have tried in vain to get the USB connection on my Westell 6100 to work. Are there some tricks to making this happen? The ethernet connection will work fine, but I cannot get the USB setup to work at...
I suggest that you use ethernet connection instead of the USB connection.
Ethernet is more stable that USB, you less likely to experience dropped connections.
Also take note that you can only use one connection at a time. You CANNOT use Ethernet on one computer, then USB on the other computer.
But if you insist to use the USB connection, you need to install the drivers. Once the usb cable is connected to the modem and computer, you will get a found new hardware wizard screen. Then you will need to insert the CD that came with the adapter to your computer.
If the found new hardware wizard did not appear, check your device manager and look if there is a USB adapter with a question mark or exclamation point. Right click on the USB adapter then click reinstall.
It should detect the drivers from the cd.
Good luck and have a great day!
Jan 11, 2010 | Westell Wirespeed LiteLine 6100...
I have an Acer Aspire6930 and a Belkin router. My internet connection will be fine for an hour, but then it craps out and says "local only" or "limited connectivity". However, all the other laptops using...
u mean to say, u r using wireless for internet access right.
Well if u r using XP, and if u r having some trouble in accessing internet, then there might some problem with the components of wireless card. so if u want to fix them, u can fix them with a simple trick.
Go to My Computer's Properties
Go to device manager,
open the tab named NETWORK ADAPTER.
u'll see ur wireless adapter listed. select it & select Uninstall.
Dont worry, just continue reading.
when u click on uninstall, u'll be asked whether u r sure to remove the device from ur computer, meanwhile u'll be given a marking space named UNINSTALL THE DRIVER FOR THIS HARDWARE.
Dont remove the driver, simply uninstall the wireless adapter.
Now its removed.
Now restart ur system, after it starts ur computer shows a ballon named, NEW HARDWARE FOUND and it will automatically install ur wireless adapter,
So ur wireless adapter is fixed by now.
and if u r using Vista, its quite easy there.
go to NETWORK & SHARING CENTRE
go to NETWORK CONNECTIONS u'll find 2 connections.
one will be named as Wireless something.
ENABLE it & click DIAGONISIS
after its completed, select RESET ADAPTER
Its done.
Hope it worked u out.
Thanks..
Aug 28, 2009 | Acer Aspire 5500 5570-2609 Laptop
Can't connect To internet w/ Wireless
try uninstalling it and re-installing it. the problem may be with its drivers.
Jan 24, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
How do you install wireless usb adaptor
A wireless USB adapter is a simple device that connects to an open USB port on your computer or laptop, allowing you to connect wirelessly to a network that is within range. They come with different connection speeds, ranges and security protection allowing you to connect to the Internet and use email servers, without complicated setups. Installing USB adapters to a computer is a simple task that anyone can perform. With just a few steps, you can access wireless networkmag-glass_10x10.gif where there is one.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Easy Instructions
  1. Step 1 Research around before purchasing a wireless USB adapter. There are many different networking companies such as Belkin, Netgear and Linksys (see links in Resources). Compare prices and features such as speed in megabytes per second (mbps). Look for wireless USB adapters with a compliance of IEEE 802.11b or IEEE 802.11g. These options give you increased security on your network.
  2. Step 2 Plug your purchased USB into a USB port on your computer. Depending on the chosen model, you may have an installation CD. Place your installation CD into the CD-ROM on your computer, and follow the setup instructions to install the wireless USB drivers. Some adapters will install automatically.
  3. Step 3 Locate the wireless icon on the lower right of your computer screen. If there is an "X" marked on it, use the manual that comes with your purchased wireless USB adapter to configure it properly. The wireless icon usually lights up when a wireless connection point is detected.
  4. http://www.microsoft.com/windowsxp/using/networking/setup/wirelessadapter.mspx#2
Dec 11, 2008 | Computers & Internet
Trouble getting a connection
This adapter's driver is pre-installed in Vista. That means that Vista should automatically see it and install it.
Power down your computer.
take out the D-link adapter.
Power on the PC. Once you get to the desktop, check in the control panel > device manager. It should not be there.
Then power off the PC again.
insert the adapter but in a different PCI slot.
Power on the PC and Vista should see it ans set it up.
The cd would not help you because the D-link Utility does not work in Vista.
I have read the the XP drivers alone would work, But try this first.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 15, 2008 | D-Link Air DWL 520 802.11b (DWL-520)...
"WPC54G is not installed"
Those install programs that Linksys uses are terrible. This happens all the time.
You probably can't use the linksys program to install the software on a Windows 2000 machine you should be able to install just the driver you need. I have never used wireless networking on a Win 2000 computer before. Win XP has sotware already built into the operating systems to deal with wireless networking.
Uninstall all Linksys wireless networking software. Restart you computer with the wirless network card install and let Windows search for the correct drivers on the CD.
Jun 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Unable to connect to the internet
Mike, Try setting up a new connection in Internet Options in Control Panel. Please let me know how this works for you.
thanks
Jan 24, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link DWA-556 (ASKU58510) Wireless Adapter Logo
178 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
