Question about Waterco Baker Hydro 55K Btu Titanium Manual Pool Heat Pump
I have a waterco insta manual 55 heat pump the heat will not start up and i have water coming out the over flow .
3 Suggested Answers
adamh294
  • 310 Answers
SOURCE: How do I replace the
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Posted on Nov 01, 2010
  • 77 Answers
SOURCE: My heatpump, a Waterco Aqua Heat XL Titane 101, now display error code "ot". What does it means and how can it be fixed?
I think that replacing the temp sensor will solve this problem.
Posted on Jun 18, 2014
Waterco spa pump. In demand mode, why won't pump switch off?
Spa pumps are not only for Heat. The pup also circulates water thru the filter and provides optimal chemical dispersion. Recommend you call the customer service see how your warranty has been holding up and go from there.
Nov 21, 2015 | Waterco Pool & Spa
I have a waterco pump and sand filter and can't get a high flow thru the pump to operate the creepy crawly
see if it works on recirculate if it does change sand or backwash if suction based and you have multiple inlets close the ones not being used if it is connected to a pool return close the other return valves or plug them while cleaning
Sep 14, 2015 | Waterco Pool & Spa
My waterco portapac was fitted 3 months ago. worked beautifully until 2 days ago. Now it is not heating. Any ideas? Thanks
it has a pressure switch that is a common failure pump waterco portapac Google Search the switch looks like this in most cases and is a gravy fix waterco portapac Google Search now you can bypass it FOR TESTING ONLY ! to see if it is indeed the culprit, it's around a $20 part and nice to have on hand Also check to see if the pump has a restriction, like a plugged impeller, debris might got into the pump and restricted flow, causing a low pressure situation ? Australian Spa Parts
Dec 30, 2014 | Waterco Pool & Spa
Waterco spa manual
The pump has two connections, the one that is in the middle of the pump is usually the input and the one on the outer edge is the discharge.
Dec 02, 2013 | Pool & Spa
Waterco Aqua Heat Titane 101, The Fan Come On But Compressor Does Not KickIn?
make sure your filter is clean, heat pumps are fussy about too much back pressure. you might try it with the filter cartdrige renoved
Sep 21, 2013 | Waterco Baker Hydro 80K Btu Titanium...
Fan Runs But Compressor Does Not kick In Waterco Aqua Heat Titane 101
I had the same problem last week. I called a technician who found out that the capacitor was defective. Cost 50$ + the service call.
If the capacitor is working, it might be the compressor...
Anyone know where I can find a manual for a focus Insta 55 Heat Pump
If Focus is the name of the manufacturer, why not try that source?
Jun 10, 2013 | Waterco Pool & Spa
I have a waterco titanium pool heater water is pouring out of drain holes in the bottom of unit.I have to keep filling up the pool every other day.what do u think is causing the water to puor out like...
in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
Mar 09, 2013 | Waterco Baker Hydro 80K Btu Titanium...
I need installation instructions for a instamatik 55. Thank you!
l'eau entre par la gauche et ressort par la droite. Est-ce qu'elle est deja brancher??? moi, j'essaie de changer la temperature en pessant sur plus ou moin et ca ne bouge pas. est-ce que les tienne change???
Jun 26, 2011 | Waterco Baker Hydro 55K Btu Titanium...
Waterco Baker Hydro 55K Btu Titanium Manual Pool Heat Pump Logo
79 people viewed this question
Top Waterco Pool & Spa Experts
Andrew Taylor
Andrew Taylor
bigdawg7299
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
