How do I tune my Digitech Audio/Video N287 into my Satilite box reciever attached to my TV. The N287 is already tuned into the TV.
cell expert
  • 30 Answers
SOURCE: Tuning playstation into the TV
THE TV DOES NOT SUPPORT PS1
Posted on Nov 24, 2007
  • 11 Answers
SOURCE: VCr connection
should be a source button so kind on the remote or on the tv
  • 19 Answers
SOURCE: TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Posted on Nov 26, 2007
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
  • 476 Answers
SOURCE: Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Posted on Feb 16, 2008
Digitech n287 need diagram please
Diagrams are in PDF and cannot upload by this window. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 27, 2013 | Televison & Video
Digitech N287 Remote control A/C
I want to buy a digitech N287 air conditioner remote. where do you buy them
Sep 03, 2013 | Music
My digitech dc-1005 will sinc ok ,but one will talk and recieve one way but not the other way, has anyone ant ideas on what could be wrong with them,im thinking the rx or tx on one of them may be ********.
There are 2 oscillator circuits in each unit- one for transmit and one for recieve. It is likely the recieving section of the one that does not recieve the other is slightly out of tune.
Jan 25, 2012 | Radio Communications
No picture with Yamaha 6130 reciever. have
The TV must be tuned to the correct input also. Please cycle through the tv inputs by pressing the input button on the tv one time, then wait 5 to 10 seconds for the tv to recognize the input signal. If nothing, press again. You don't say which tv you have but many newer models have 5 to 7 input sources you will have to cycle through to find your signal.
With out more information, this is just one step in finding out what could be wrong. Please rank me accordingly.
Good luck.
Feb 28, 2010 | Yamaha HTR-6130 Receiver
How do you tune a hitachi projector tv a 1992
1992 tv has an electronic tuner, if it doesn't tune, then you need to replace the tuner, or you can bypass the tuner by hooking up an external tuning source, vcr, cable box, sattelite box, to the audio video jacks and putting the tv on video 1 or 2 whatever input you hook it to.
Sep 07, 2009 | Televison & Video
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
I'm trying to set up my JVC LT-32DF7BK. I've already attached a BT vision box, but the TV won't tune in any channels as it says no signal. I've checked all the leads and aerial point with another TV and...
Try an antenna directly on the tv to see if you get any stations. This will assure you that the tuner is working. Then hook up the new box and tune tv to channel 3 and turn box on. You should get some kind of display. If no luck you could hook audio/video cables from the audio/video output on the box to the video 1 input on the rear of your set. Then switch tv input to video 1 and turn box and tv on. This too, should give you something on the screen. Make sure the antenna is hooked up to the "ant. in" on the box. This should help, Russmann.
Jun 20, 2008 | JVC Televison & Video
KD-36FS130 Digital Set-Up?
I did not know that the Sony FS series has digital capability. This is supposed to be the most basic model of CRT flat screen TV that Sony made.
You can get a digital cable or satellite box that outputs analog baseband or component analog video and analog audio. You can then connect this box in to the TV set. The TV will then display the analog signal from the digital box.
If your cable or sat box is able to tune in standard channels, but cannot tune in the ones that are on digital service, then the fault is with the box, or the cable or sat system. This you should address to the TV service provider.
Jerry G.
Apr 19, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
We can't get the dvr/cable box to work with the tv
Assuming you have connected the DVR/Cable box with a standard co-axial antenna cable, switch on the box and go to the tuning menu on the TV.
Tuning details are in the TV manual. If you don't have the manual, download here:
https://www.p4c.philips.com/files/1/13mt143s/13mt143s_dfu_aen.pdf
When tuning is completed go through the channels to find the cable box. (Note: TV will not tune to the box if it is not switched on when tuning)
If there is still no connection, the DVR/Cable box may need connecting with a composite video cable (red / white / yellow RCA connectors), rather than just a standard co-ax cable.
The connection is at the front of the TV. There is no red connector on this TV so you will have to use an adaptor to connect both left and right (red & white) audio into the white socket. Select AV on the remote control.
Mar 11, 2008 | Philips Magnavox 13MT143S 13" TV
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
