Question about Intel Motherboard
How to installed audio / sound driver in my laptop?
  • Intel Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 19, 2011
I have no audio output
Please check your audio driver. If your audio driver missing, download and install it here :
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Toshiba-Satellite-A215-S7472-Realtek-Audio-Driver-6-0-1-5433-Logo.shtml
Thanks
Jul 18, 2011 | Toshiba Satellite A215-S7407 Notebook
Not getting audio sound
If the audio drivers are not installed on the laptop then you will not able to hear any audio sounds. If you have the audio drivers CD then go ahead and install them if you dont have the audio drivers then login to your laptop manufacturers website and once when you enter your model number and you operating system then you wil be able to download and install the audio drivers.
Dec 21, 2010 | Computers & Internet
Sir mere paas compaq 610 model laptop hai.or mere paas motherbord CD nahi hai isliye mere laptop me sound nahi aa rahe to mai kya karu?
You can download all the drivers for your Laptop from this link (click here).
If you are looking only for the audio driver, click "Driver - Audio", you'll see two links, install both the drivers, but you need to install the "Microsoft UAA..." and install the "Realtek High Definition Audio driver....", otherwise you'll not get the sound even if you install the sound driver,
Sep 07, 2010 | Computers & Internet
My laptop audio driver shows as there is no drivers installed
what cd did you install >???a sound or a mother board cd instaler find the avance sound or c3 media to active your sound
Jul 26, 2010 | Compaq Audio card Sound Card
No sound or voice from the pc?
Have you installed the audio driver? If you have installed an audio driver, it most likely an incorrect one. To check if you have installed a correct audio driver. Go to the Control Panel - click on Sounds and Audio Devices - click on the Sounds tab - click on any of the Program events and click the play button. If you hear a sound from the speakers the audio driver is correctly installed. Also connect a headphone to the laptop and repeat this test.
If you don't hear any sounds and the play button is greyed out, it means the correct version of the audio driver wasn't installed.
You can check if this is true - go to Control Panel - System - Hardware tab - Device Manager and look for any devices that have a yellow ? against the device. This indicates a device driver is required to make this device work.
You need to download the correct device driver for your model laptop, and it must be a XP or Vista version that matches the Windows version that is installed on your laptop.
Jun 03, 2009 | Compaq Presario Notebook
Audio drivers is install but not work
is the sound manager not muted? did you try checking the volume settings? has it been selected as the primary audio device in the sound applet in control panel? try checking.. then pm me again
Jun 01, 2009 | Compaq Presario Notebook
Sound drivers
download the sound drivers from ur laptop company website ...
Apr 07, 2008 | Computers & Internet
No audio in my laptop prisario 700
First u check it in device Manager,whether sound driver is install or not.If sound driver shows yellow mark then sound driver is not installed.I tell the following steps to install sound drivers.
First u install the UAA driver.After installation,u restart laptop.Next u install the Audio drivers.Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\****** folder . Select the .inf file, click open and Continue with the onscreen instructions.
If ur laptop have Windows vista operating system then u click on Start - Programs - Recovery Manager- Recovery manager.In that recovery manager,u click on next button.Its shows the software reinstalltion page.There u select the NO and clink on next button.Its shows the Hardware drivers reinstalltion page.U select YES and click on Next button.Its shows the Hardware drivers list.There u select the Audio driver and click on next button.After reinstalltion,u restart laptop and check it.If u get same problem then u take from nearest service center.
Thanks
Feb 28, 2008 | Gateway Solo 5300 Notebook
Intel Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
