Question about Cycling
Need to put on the height adjustment piece. - Cycling
  • 2,334 Answers
Explain, please. What in your mind is height adjustment piece? 40+years in cycling - never heard about such a thing.
Posted on May 19, 2011
How do u adjust headlghts on 1991 gmc seirre
adjustment is on the top of the light and the side.
Jun 22, 2014 | 2003 GMC Sonoma Extended Cab
Binding adjustment
There is (should be) a screw visible on each of the toe and heel pieces when looking down from directly above. That screw will adjust the height of the piece that clamps down on the top of the tabs on the heel and toe of your ski boots. For proper height measurement, use a credit card (or similar thickness card) and make sure you can somewhat freely slide the card side-to-side under your boot when it is in the binding and clamped down as when you are skiing. Too much play, and you will feel a sloppyness while skiing. Too little and you risk the binding not releasing properly caused by stiction. You can find demonstrations on YouTube also.
Apr 04, 2014 | Fischer Skis Fischer RC4 Z 17 Freeflex...
How to adjust the headlamp height, I think my lights are aiming to high. Cheers
I suggest that you make a test of the proper height of your lights, before you attempt an adjustment.
This can be accomplished by driving your Mazda up to within 10 FT of a blank wall.
Next take a piece of masking tape and tape it to the wall at a height of 30 inches.
Put your headlamps on - on low beam - the lights should shine on the tape.
Good luck, and let me know how you make out.
Oct 10, 2010 | 2006 Mazda Tribute
Can you adjust the seat height on my kawasaki 125?
No what you can do is take it to some one who does custom seats and discuss having it re done with thicker foam piece raising it to your comfort.
Jun 01, 2010 | 2004 kawasaki KX 125
With a newly tiled floor, my counter depth GE Profile model TPX24BRYA (14 yrs old) now is about 1/32 in. too tall to fit into the cabinet. Can I, and if so, how do I adjust the height?
you need to take off the feet/adjusters from underneath and fit thick felt pads so that you dont get vibrations through floor,and so that when you slide the unit back in it wont scratch the tiles......i put mine on a piece of upsidedown vinyl flooring mat....easier to slide in/out..
Apr 11, 2010 | Refrigerators
Just need the height setting for the floats the
YOU CAN ADJUST FLOATS WITHOUT SPECIAL TOOLS. ALL YOU NEED IS A FOOT LONG PIECE OF CLEAR TUBING, SIZED TO FIT THE BOWL DRAIN. SET FLOATS AS CLOSE TO WHAT THEY WERE WHEN YOU REPLACED IT. INSTALL THE BOWL AND PUT THE TUBE ON THE DRAIN. OPEN THE BOWL DRAIN SCREW WHILE HOLDING THE TUBE UP BESIDE THE CARB. WHEN YOU GET THE TUBE BESIDE THE CARB ASSY., THE GAS IN THE TUBE SHOWS YOU THE EXACT LEVEL OF FUEL IN THE BOWL. FROM THIS YOU CAN MAKE ANY ADJUSTMENTS NECESSARY FOR CORRECT LEVEL. THE LEVEL SHOULD BE RIGHT BELOW THE PLANE WHERE THE BOWL MEETS THE CARB BASE.
Oct 22, 2009 | 2006 Yamaha V Star Classic
Getting the height adjustment to work
is this a piece of **** dirt devil? if so, even when you get it back together the design is so flawed that it will keep breaking the belts, I've already gone through 3 in a week! see my other suggestions to remedy this.
Jul 11, 2009 | Dirt Devil Featherlite Bagless Vacuum...
I have no idea how to get the stupid straps back in. Can I get some dang directions?
My daughter has a car seat just like this one, and I wash it about once a month so I hope I can explain this detailed. First, at the base there is a metal rod that will need removed. When you take this rod out the base and seat will seperate. Set base aside and turn seat upside down. Take your strap and put an end into each slot. Turn seat over and pull your straps even. Put the two black pieces for your latch on (one on each side) then put you chest pieces on and run straps thru slots on back of seat. Turn seat around and make sure the straps go OVER the silver bar in back (this allows you to adjust shoulder height) Secure to the metal piece that runs to front for tightening adjustment. Set seat back on base and replace rod. Hope this was helpful.
May 13, 2009 | Eddie Bauer Deluxe High Back Booster...
Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
Cycling Logo
41 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
