Question about Whirlpool Washing Machines
Start a load of laundry, & a few mins later it stops & says sud. It done it about 4 times. Tried smaller loads, & same outcome.
  • 110 Answers
I am assuming that you are using a HE front loading washer. If this is the case, there are two or three possible causes:
1. Using too much soap (use the lowest soap line on your HE detergent);
2. Using incorrect soap (must be HE)
3. There might be something in the load that contains soap or contaminants that is causing the correct soap to act irregularly.
Try running a bleach-only load with no soap. It might take several loads to correct the condition; I occasionally have this problem on my Duet.
Posted on May 19, 2011
SUD AND F-35 PROBLEM
SUD= The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future
As far as F35. Check your owners manual to see if its in there. Also if you remove the top lid ( a couple screws in back hold it in place) and check inside you will get the technician diag sheet which will have codes.
Jul 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds was displayed. stopped machine can't get it to re-start
to much soap on the water level sensor, remove laundry, pour in clean water manually if you have to, problem should go away
Aug 08, 2009 | Maytag MAH2400A Front Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Code LE comes on my washer it is a LG wm2075cw
Symptom Error Codes
Answer LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 17, 2008 | LG Washing Machines
Calypso washer
You likely have clothing stuck under the wash plate. I received "out of balance" & "suds lock" errors & tried resolving the issue with extended spin and extra rinse cycles with the same results you have describe "not going below 7 min left in cycle". Thinking I had a clogged drainage hose, I removed the back panel after hose disconnection and "snaked" drainage hose - had problem here once before. Some lint here again but not enough to cause problem I reasoned, then I move to the basket area. Remove the plastic cover in the middle over the wash plate with a flat head screw driver by pressing in on indented tabs. Once removed, use a 10mm socket & ratchet to remove wash plate. I had three pieces of laundry underneath, 2 socks, & a microfiber runner's tank top. I concluded this to be the major problem caused by the small items entering in the gap in the rubber ring around the wash plate. This gap has increased over time by the ring's shrinkage. I am applying silicone to close this gap, but will also use a mesh laundry bag for smaller items in the future. Also recheck the leveling of the machine - mine was off considerably. Once I reassembled the wash plate & hose connections, the machine began working properly. No doubt, this design was not well thought through.
Apr 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
125 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
