Question about Moen 7907 Chateau Two-Handle Kitchen Faucet with Side Spray Chrome...
How do you get the spout off? - Moen 7907 Chateau Two-Handle Kitchen Faucet with Side Spray Chrome...
    Genius:
  • 1,739 Answers
Information on your faucet can be found here:
http://www.moen.com/chateau/chrome-two-handle-low-arc-kitchen-faucet/_/R-CONSUMER%3A7907
The exploded parts view can be helpful is seeing how your faucet is assembled:
http://www.moen.com/shared/pdf/7906pt.pdf
First turn off the hot and cold water supply taps. Then to remove the spout you simply unscrew the spout cap counter-clockwise; you should then be able to lift the spout up and off the supply post.
Posted on May 19, 2011
91 4.9 won't run with spout in, runs with spout out.
spout is computer controlled timing check the spout circuit for short to ground corroded insulation on harness where it runs along the intake also look for swollen or oil soaked sections of the harness
Dec 05, 2012 | 1991 Ford F150
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Tub spout, cannnot lift up lever for shower, has seized up, what can be done
The tub spout can be replaced very easily....
Check if it spins off (threaded) or if there is a allen set screw that you get to from the bottom of the spout....the spout will then just pull off....
They sell new spouts at Home Depot, Lowes, or Plumbing Supply houses....the universal spouts will fit either configuration...
heatman101
Mar 08, 2011 | Kohler Home
Water comes out spout and shower head at same time
Hello gruber d, you need a new spout. When a spout is working properly you raise the knob on top and it slides a baffle over the outlet at the spout. Once the water is blocked from flowing out of the spout it forces water up and out of the shower head.
You may also remove the spout and see if you can get a closer look and see if you can make some kind of adjustment to it.
Removing the spout;
1. Put a cloth around the spout to protect the finish.
2. Adjust a pipe wrench to fit over the spout and the cloth.
3. Turn the spout counter-clockwise to loosen.
My goal was to provide timely and accurate information. If this has been helpful to you, please
consider taking a second to click on the, " this was helpful ", button.
Than you!
Jan 13, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Tub spout is calcified onto pipe and will not twist. i don't want to ruin pipes , how do i get it off?
First make sure you have a thread type spout. Look on the underside of spout for a set screw. If one is not found then you have a threaded spout. If you have set screws then it is a friction spout loosen set screw and twist/pull spout. A couple things you can try to loosen the calcium build up. Use a calcium buildup cleaner (may or may not be able to reach area) you can also try rapping on spout with rubber mallet calcium is hard and this might break it up (cause fractures in the calcium) then take a no mark wrench (simuliar to what you take oil filters off with) and turn spout counter clockwise. It may be hard but it should come off. If the spout pipe is galvanized it may come off inside the wall before it comes off of the spout. No worries just keep turning until off. Once off you can work on the spout end then reinstall. Make sure when you reinstall you place teflon on the thread ends. Hope this helps, thanks for using FIXYA. Good luck and have a great day. Jeff
Apr 07, 2010 | Price Pfister 01-311 Shower Head, Tub...
When i pull up on the spigot, a substantial amount of water still flows from the spout rather than from the shower head. We, therefore, get an insufficient amout of water from the shower head. How can I...
The stopper inside the tub spout needs to be replaced depending on the make and model you may be able to replace just that part (higher end Models) otherwise you have to replace the spout. If you know the make and model I could help you further with this. If you decide to change the spout which you could get at any hardware store, DIY store, there are two types of spout hookups. One is friction the other is threaded. To see what type you have look underneath the spout if you see a screw hole then its friction. Either a screw driver or allen wrench will be required to remove spout. Loosen set screw and pull spout. If it's threaded turn spout counterclockwise to remove. Be sure to apply new teflon tape to threads before installing new spout. Tighten with hand until snug and apply a bead of caulk around the top and sides of spout at wall.
I hope this was of help to you, please rate the answer on how helpful it was. Good Luck and have a great day. Jeff
Apr 04, 2010 | Chrome Home
I need to replace the two o-rings and the bushing for the spout of a Delta 2467 series. How do I get the spout out?
The spout is locked in place with a nut. Loosen the nut, raise it above the spout post, and the spout itself will simply lift up towards the ceiling.
Nov 16, 2009 | Delta Plumbing
Moen 7907 Chateau Two-Handle Kitchen Faucet with Side Spray Chrome... Logo
923 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
