Question about Schwinn Meridian Adult 26-Inch 3-Wheel Bike
I just received a 3 wheel adult trike from walmart via fedex. I read thru the manual, but no where does it discuss the rear axel assembly and chain to the main frame. It only discuses standard bikes. Please email me the instructions to complete the assembly properly of your adult 3 wheel trike. Thank you
  • 2,334 Answers
  • Old Really May 27, 2011
    Mine came with a single page "Owner's Manual Addendum for the Schwinn Adult Tricycle" that explained those things not in the regular manual
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
Can I use any chain to replace lost rear chain?
No, schwinn has different specs from most bikes; http://media.schwinnbikes.com/media/s/c/schwinn_meridian_manual.pdf
oe see http://www.bikeforums.net/utility-cycling/701831-schwinn-meridian-trike-info.html
Oct 03, 2015 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Where can I find instructions on replacing a back axle of the Schwinn Meridian adult three wheel trike
This is a difficult operation, you can try a video from Utube. But the best solution is take your trike to the local bike shop.
Oct 17, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
What sort of tool is needed to change the chain on a schwinn meridian adult trike?
Find the master link first. It will be the only one without the hourglass shape (flat on the sides) I just use a needle nose or a screw driver and a light tap with a hammer using the screw driver as a wedge. Using this method make sure to keep your eye on the master if it flies off.
May 20, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Removing rear wheels
you dont need to remove tires from bike, turn bike on one side so back tire is flat to ground, this give you the other tire in air for easier access. Use a tire removal kit to take off tire there relatively cheap, try walmart, they usually have the tires and the removal kits too...
Mar 28, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Received this bike today via Fedex. Box contains no assembly instructions. Where can such instructions be obtained?
www.Schwinnbikes.com has owners manuals, assembly instructions and more.
Here is a link to Bike assembly from them. Your specific bike is listed under cruisers.
Dec 15, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I have a new trike that may have ome shipping damage (bought at flea market) The rear axel appears to be bent. severe wheel wooble. is there some adjustment in those set screw type bolts in the center of...
The set screws in the center of the axle are there to keep the axle centered in the frame. Only the right wheel is powered which also means only the right wheel brakes when operating the rear brake. This is because the rear wheels must be able to spin independently when turning because the outside wheel will move faster. Unfortunately no one builds differentials at this price.
If you have wheel wobble you need to determine if the axle is bent or the wheel is not true. Prop up the rear of the bike on a stand and remove the problematic wheel. Manually pedal the bike and check the axle as it spins. If the axle is wobbling then it is bent and will need to be replaced. If it spins true then the wheel is the culprit.
The axle is relatively inexpensive and can be ordered through a Schwinn dealer. Any bike shop should be able to true a wheel for around $15-$20.
Sep 23, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Schwinn Meridian Adult 26-Inch 3-Wheel Bike Logo
2,918 people viewed this question
Top Schwinn Cycling Experts
Tony
Joseph Hoffmann
numbers819
Level 1 Expert
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
