Question about Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD
The dot moves inthe scope - Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD
  • 2,418 Answers
Check out the Tasco support site for info on their warranty and repair sites. Tasco support. Hope this helps Fix Ya up..
Posted on Jun 10, 2011
Crosshair dont move
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Aug 09, 2012 | Bushnell Banner Rifle Scope 3-9X 50...
I'm sure this will sound stupid, I just bought a rifle with a Tasco red dot scope on it and have no idea how to activate the scope. Any help would greatly be appreciated. Thanks
No, that doesn't sound stupid. It's always a good idea to get all the information before using firearms and their accessories, and I'm happy to help:
The large knob on top of the scope is the rheostat, which is used to turn on the red dot, and adjust the brightness. It can be adjusted from "1" (dimmest) to "11" (brightest). You'll have to be looking straight down the scope to see the red dot, since it is only visible when you're aiming. If you turn on the scope to the brightest setting, and you look through like you are aiming, and the red dot is still not there (or very dim) then you probably need to replace the battery. It uses a 3 Volt coin-style lithium battery, type 2032. Unscrew the battery compartment on top of the rheostat and put the new battery "+" side up. Then replace the battery cover, and you should be good to go. Turn off the scope when you're done to save the batteries.
Since you bought the rifle with the scope already installed, it's probably already sighted in, or pretty close to being sighted in. Adjusting the windage and elevation on the red dot scope works just like other rifle scopes. The knob on top moves the point of impact up/down, and the knob on the side moves left/right. For this model, each click of adjustment moves the point fo impact by 1/2" at 100 yds, 1/4" at 50 yds, or 1/8" at 25 yds.
Be safe, and have fun!
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
Dot moves around when looking through scope, if you dont hold exactly perfect every time bullets are everywhere
if the dot is fixed in scope the scope is ok,,,so its down to you to look through the scope the same way every time,,,what your doing is looking through the scope from a different point every time this will cause the point of aim to wonder,,,keep your cheek on the same spot on the stock each shot
Nov 30, 2010 | ATN 4-12X60LU Daytime Rifle Scope
Parallax problem with trophy 1x32. dot moves when i move my head
it will silly? when you go to shoot put your cheek in the same place on the rifle stock or the point of aim will be off,
Nov 29, 2010 | Bushnell Trophy 1x32 MP Red Dot Scope 3...
NEED INFO ABOUT ADJUSTING WINDAGE & ELEVATION ON MY MILLETT SP2 RED DOT. I LOST OWNERS MANUAL &NEED TO KNOW WHAT EACH CLICK IS EQUAL TO AT 100 YDS
the best way to sight in your red dot is clamp your gun in a gun vice or work mate? so it cant jump about!!!!!!! look through the barrel at a post say 100yds away then tweek the red dot or croos onto this post,,then test fire the gun and tweek the scope till its shooting were it points,,easy,,,
dont let the gun move at all,,,,you need to remove all the wobbely bits,,your the bigest wobbely bit?
an im not being nasty,,,you cant tweek a scope hand held?
Nov 27, 2010 | Millett SP2 Compact Red Dot Sight 5 Min...
Red dot seems to disappear when you move the sight right to left or up and down.
You are simply moving the dot out of the field of view.
The Aimpoint is set up to allow you to hit now matter where in the field of view the dot appears. High, low, right, left, it doesn't matter. If you can place the dot on target, your bullet will hit where the dot appears. Too much angle away from the center will move the dot out of your field of view however, This is apparently what is happening to you.
Oct 10, 2010 | Aimpoint 10338 CompML2 4 MOA
Cross hairs wont move when trying to ajust
The cross hairs don't actually move when you adjust a scope, instead, they are contained within what is called the erector tube. When you adjust your scope you are actually moving this tube, thus the cross hairs do not move around in your field of view
Sep 19, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
How to sight scope in /what scope do i have ?
Real simple Scott.
You can 'Zero' your scope/rifle even if you don't have a laser bore-scope device.
All this is assuming that your used rifle has not had the barrel shot out and that the head-space is still within specs for that rifle. Have all this checked by a gunsmith first. You can dress up a piece of poop and it will be pretty, but still be poop. Make sure yours isn't to begin with. As for the scope, it's hard to tell unless there's obvious damage or it's an antique past it's prime. Try to get as good a quality scope as possible to start with. You would not put one ply tube tires on your mustang and expect to get the best performance, so...
Most rifles are capable of shooting quite accurately, and all things being equal, it's the shooters job of making it happen.
Ammunition should be considered as well. Toss your old military ball ammo and junk from overseas, both of'em. If you want to shoot accurately and consistently, you must spend the bucks for the best ammo you can afford.
You MUST KNOW what the BALLISTICS are for the Cal./type/weight ammo you will be shooting and the corresponding distance it will be shot from.
Make sure your rifle is CLEAN inside and out. A clean rifle is a happy rifle.
Make sure that your rifle 'fits' your body's frame and that you are familiar and practice good rifle shooting techniques.
'Zeroing' is best done from the prone position as that is the most steady position to shoot from.
Do you have a bi-pod attached? Whether you do or not, sandbag your rifle securely but still able to make small adjustments to the rifle position itself.
Set up a target with a 1" black dot at 50rds.
Remove the bolt.
Lay down with your rifle but stay OFF of it, touch it as little as possible at this point.
With out disturbing the rifle look through the bore downrange to your target. Locate the black dot and if necessary adjust your rifle from the **** end until you can see the dot through the bore. Keep making minor adjustments until the dot appears to be centered in the bore. Make sure rifle is secure and steady at this point.
Then without moving or touching the rifle, look through the scope using the correct eye relief distance and locate the black dot. Now using the Vertical(Elevation) and Horizontal(Windage) adjustment knobs, move the reticles(crosshairs) until they both are centered on the dot.
Again look through the bore to make sure that you have not moved the rifle and that the dot is still centered in the bore. If not, adjust the rifle again to center the dot, then go back to the scope and adjust as necessary to move the RETICLES to the center of the dot. It may be necessary to repeat this a few times before you have achieved this particular goal.
You do not mention brand/model of your scope. It probably adjusts the reticle or crosshairs in 1/4minute increments (1/4 inch increments with each individual click movement of the turret knobs at 100 yard distance). IT IS CRITICAL for you to know how your own scope adjusts.
Now, bolt back in and load 3 rounds of quality ammo.
You are going to shoot 3 rounds in succession without getting off the rifle or making any adjustments to the rifle or scope. You are looking for a 3 shot group to determine a rough average of how far and where the rounds are impacting initially. Use good shooting techniques, breath control, relax, sight picture, squeeeeeeze the trigger, follow through the scope, there is no need to take your eye off the scope while doing this, hold your shooting position for all 3 shots.
You will now have to make adjustments of the scope unless you are hitting the black dot already which is quite possible.
Remember that if your scope is a 1/4" adjustment at 100yds, it means that for each 'click' that you adjust either Vertically or Horizontally at 100rds, the reticle/crosshairs will move accordingly 1/4 of an inch Vertically or Horizontally. At 200yds, one click will move it 1/2 inch, at 300yrd it will move it 3/4 of an inch, at 400yrd, it will be 1 inch.
Right now you are at 50yrds distance from your target. Each click from here will move the RETICLES about 1/8 of an inch so estimate the distance that your most central shot of the 3 you fired, is from the black dot and adjust accordingly. You're not moving the RIFLE here, you are simply moving the scope RETICLES so that your point of aim and point of impact coincides.
Now load 3 more rounds of ammo and repeat as above. You should only have to use about 9 rounds to get on target, the black dot.
Once you are hitting the black dot at the 50yrd line, move back to the 100yrd line. Put a fresh black dot on your target and repeat the steps from above. Your first 3 shots from the 100yrd line should be about 1/2 to 1 inch low. Don't follow the bullet strikes! Keep your point of aim and the crosshairs ON the black dot no matter where the bullets are striking on the target. Remember, now at 100yrds your RETICLES will move 1/4inch with each 'click' of adjustment of the turret knobs.
Adjust the scope as needed at this point. Once you are 'ON TARGET'(hitting the black dot), you now have your 100yrd. 'ZERO'.
Now that you have this 100yrd ZERO, you must loosen the turret knobs , both the Vertical(Elevation) and the Horizontal(Windage) turrets and align the '0' on the knobs with the '0' on the scope at the base of each knob. Now tighten the set screws and you are set to go. If you want to know your 200yrd 'ZERO', simply move back to the 200yrd line, your 'come-up' or elevation adjustment should be about 7-9 clicks, at least for .308 168grn HPBT, but you will figure it out for the Cal./brand/wght ammo you are using. WHATEVER the 'come-up' you need to make at 200, 300,400yrds or wherever, be sure to make note of the number of clicks you used to find the Zero for that distance. Use a fine point endelible marker and actually write the ZERO info on thestock of your rifle. You don't need to mark anything for the 100yrd ZERO, it's a given already. Write; 200/9, 300/18 and so on. You should also get your ZERO for the intermidiate, 150yrd, 250yrds etc, distances as well.
Remember that weather conditions, source and intesity of light conditions, your own body condition at any particular moment or day can have an affecf on how you and/or your rifle shoot. Good luck.
Mar 21, 2009 | Tasco ® Silver Antler® 3-9x40 mm Scope...
Tasco 6-24x42mm rifle scope parallax adjustment
Here's what you need to know about Mil Dots and rangefinding.
When you look through the scope you should see 5 mil dots on each axis, your scope may have broad lines taking place of the 5th mil dot if it is a "modified" mil dot scope. For measuring purposes, 1 mil is the distance from the center of one dot to the center of the one directly above or below it. 3/4 of a mil is the distance from the top of one dot to the bottom of the one above it, or the "space in between dots". 1/4 mil comprises a single dot, the space between the top of one dot and the bottom of that same dot.
A quick calculation is Size of Target (In Yards) x 1000 / Size of target in mils = Range in Yards
Miliradian or "Mil" is an angular unit of measure, so if you were shooting at 1000 yards and moved up 1 miliradian that would be one inch impact moved up.
Anyway lets say you have a 30" target and we need to find the range... using your scope you place the bottom of the target at the CENTER of a mil dot and count how many mils up, good estimation is key... I'll draw a little text diagram, an asterisk * will be the target top and bottom, and parentheses () will be a mill dot
Now lets assume the asterisk on the left is the bottom of your target and the one on the right is the top, I put Ten Hyphens in between each dot so if you count from the left you should get about 1.6 Mils. Its real easy to do it in your head, you already know two whole dots is one mil so you just have to estimate whats to the right (or top if you were looking down a scope).
So we know the target is 30" and we have a Mil Reading of 1.6
30/36= .833 so 30" is .833 Yards
So now we can use the equation .833 x 1000 / 1.6 = 520.6 Yards is the distance of the target
Now you can also use Mil dots to do hold over for when the target moves or for wind and elevation but that gets extremely complicated.
Parallax in Rifle Scopes is explained here
http://www.6mmbr.com/parallax.html
There are many books and websites to confirm what I've said here, but the best way is to go out to your range and talk to some long range shooters and show them your rifle/scope etc and get hands on help.
Mar 16, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Red dot finder scope
Simple-- you can also do this during the day on an object at least 100 yards away-- but at night; get the moon centered in the eyepiece and without moving the telescope center the red dot on the moon. This will get you almost aligned-- then put a bright star in the eyepiece and readjust the red dot to center the star.
Jan 09, 2009 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD Logo
227 people viewed this question
Top Tasco Optics Experts
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
