Question about Cub Cadet Garden
I have a cub cadet AGS 2160. Recently the breather tube had managed to become detatched from the air cleaner houseing. When this happened oil began to leak from the tube. I replaced the breather tube which seemed to solve the issue. However now oil is leaking at an alarming rate from the base of the breather tube when the mower is running. What could cause this and how can I make it stop?
3 Suggested Answers
  • 109 Answers
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Posted on Jun 03, 2009
  • 12 Answers
SOURCE: i was going to replace my deck belt on my cub
if you go to cub cadet.com click on info center tab then owners manual put model and serial number in it will show you a diagram
Posted on May 05, 2011
Cub cadet 4621 zx390 single cyl. oil comes out of dip stick tube where is breather located
Find your carburetor assembly. you have a rubber tube coming from that to your to your oil breather. you can also look up your parts manual using the same info you gave here. Cub cadet 4621 zx390. looks like a kohler engine.
Aug 29, 2017 | Cub Cadet Garden
OIL LIGHT CAME ON EXACTLY AT 50 HOURS. i RECENTLY CHANGED THE OIL. Why is oil light on? also oil dip stick reads full.
You may have to reset it.. is this a cub cadet.. if you have the owners manual, it should have the step by step procedure.
Or go to you tube and type in oil light reset for cub cadet or whichever make u have
Nov 08, 2015 | Garden
Cub cadet 1440 oil all over engine, in carb, and plugs come out black with oil all over them
Is it coming from the Breather hose? try taking out the air filter and see if that stops it. If air filter is clogged , it will cause Crank Pressure.
Also check oil level if too high it will do this. Sometimes the carb will let gas past and into crankcase filling teh crankcase above 'Full' mark
Sep 25, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Blowing white smoke
to much oil in lawn mower need to drain some out fillt to line on dip stick
May 28, 2013 | Cub Cadet Garden
Blowing white smoke
Either the valve in the breather is not working properley and causing a pressure rather than a vacume in the crankcase, or the piron rings or cylinder bore are worn.
Breather tube throwing oil into carb
Oil coming via the engine breather can mean a worn engine, it could be as simple as an over filled sump, or the breather valve itself is not working, the breather valve allows the crankcase pressure out of the engine.
Apr 20, 2012 | Cub Cadet Garden
I'm looking for help diagnosing a trouble with my model 1863 Cub Cadet, and wondered if you could help. The problem is that the engine sprays a very light mist of oil up under the hood and on top of the...
Check your crankcase breather (on side of block) . It could need cleaning/replacing and is loaded with oil/sludge causing this excessive blow-by to occur. Also check the tube running from the breather to the air filter housing. Make sure it is clean and clear.
Aug 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Jun 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2160 PTO problem
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Jun 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
74 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
