Question about Lowrance HST WSBL Single Frequency Transducer Temperature
Had to replace my original tranducer with a new one. New one is installed. temperature is reading 32 degrees constantly. not sure if they sent me the wrong model or if I need to reset something?
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
What is the mormal temperature swing of a Refrigerator?
What you call temperature swing, is hysteresis. For a refrigerator it only is allowed a few degrees. 1 or 2 up and down. A swing from 32 to 45 is far to big. Unless the factory can prove they advertise these figures. I would never buy a frig like that.
I would contact the dealer and ask him / her to replace the thermostat and if that is not possible to bring another refrigerator.
Something is really wrong with yours.
Jun 11, 2014 | Kenmore Side by Side Refrigerator
Temperature says it is -32 degrees outside when it is + 32 degrees
Really? waah...waah. My car doesn't even have a temp gage. It's a good car. Don't worry about it. Use the weather app on your phone.
Jun 05, 2014 | 2000 Pontiac Grand Prix
1998 isuzu hombre will not start when temperature gets below 32 degrees
run fault codes and look for a faulty ambient temperature sensor as if it is faulty the ECM will not know to enrich the mixture ( like pulling on the choke)
Jan 01, 2014 | 1998 Isuzu Hombre
Replacing oven sensor on GE Range JGSP31GER1WG
You can try the new thermostat and if the temp is still off, then you you will need to replace the control.
Dec 29, 2011 | Whirlpool Stove Oven Sensor 8053344
2003 ford explorer no heat and clicking in dash board
Clicking sound is your blend door actuator stripping it's gears and failing to open the door that directs the blower air through the heater core. Follow the sound to the actuator and remove it. Install a new one. You may have to remove some panels to get to it. The part is shown below and costs $32 at autozone. Please let me know if you have questions.
Dec 04, 2010 | 2003 Ford Explorer
Temperature is wrong
Many ranges show a beginning temperature that is higher than actual temperature, then the gap closes as it heats up.
Use a accurate oven thermometer to check your temps.
If it is faulty, it will not recalibrate to offset 200 degrees. You will have to replace the ERC.
Mar 20, 2009 | GE 24" Built-In Single Gas Wall Oven
Lowrance HST WSBL Single Frequency Transducer Temperature Logo
21 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
