Question about Audio Technica ATH-M30 Professional Headphones
Left side of headphone stopped working. - Audio Technica ATH-M30 Professional Headphones
The left side of my earphones randomly stopped working, can it be fixed?
Sounds like the wires are broken from stress or the mini jack is not inserted completely.
Jul 13, 2014 | ifrogz EarPollution CS40 Headphones
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
Boss oethe left side of my headphone is stop working
The most common cause for this, is a loose wire connection to that speaker (as opposed to the speaker being faulty).
Has anyone pulled the cord too tight or tripped on the cord? If yes, then the internal wire connecting that speaker has an internal break somewhere.
Try the following:
1) Plug headphones into music device and turn on.
2) Gently press the wire 'in' at the left earpiece (or wiggle at the earpiece end). If sound returns intermittently, then you have n internal wire break in that end of the cord.
3) Gently press the wire 'in' at the plug where it connects to your player (or wiggle the cord at the plug end). If sound returns, then there is an internal wire break at this end of the cord.
In the case of broken internal wires, it is possible to repair.
Although very fragile, it is possible to resolder these tiny wires (you'll have to burn off the enamel coating around these wires first) back onto their respective connections, or onto a new plug.
Good luck....
Jan 13, 2012 | Bose On-Ear Headphones
I have the RS120. It worked ok for about 2 years and then the right side stopped working. The left side works just fine. I opened up the sides and it seems that there is no broken solders or anything...
well it seems your right earpiece is started to get broken...clearly saying that the coil has static and would result to an open coil.....try to replace with a new one...good day...
Feb 12, 2011 | Sennheiser RS 120 Consumer Headphones
The left side is not working
You could have a look at my tip on repairing dodgy cables and plugs on headphones. Though if it will be any good with your type of headphone, is up to you to evaluate.
May 11, 2010 | Sennheiser CX 300 Consumer Headphones
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
Audio Technica ATH-M30 Professional Headphones Logo
65 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
