Question about Philips 20PT6441 20" TV
How can i unlock philips hotel tv 21ht3302/41?
How can i unlock philips hotel tv 21ht3302/41using remote control?
  • Anonymous Mar 04, 2009
    this dos'nt work...
  • mohamed tuan ameen noor
    I have PHILLPS tv 25HT5403/OIZ un able to un lock i only remember 7753 can u help me to un lock the tv
    ameennoor.mtan@gmail.com
Hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Posted on Apr 17, 2010
  • 1 more comment
  • jeepcj6 Dec 17, 2010
    no solution
  • jasafolk Feb 13, 2012
    When i push the code the menu comes up bur i cant navigate inn it.. when i push up or down the tv changes the channel instead of navigating the menu. Anyone got Any ideas??
  • Anonymous Jan 25, 2019
    fayyazh404
  • 69 Answers
You can't unlock without paying usually. You would have to ask some kind of hotel staff.
Posted on Aug 14, 2008
TRY THE SETUP CODE "0, 6, 2, 5, 9, 6 + MENU" TO ENTER THE SERVICE MODE
Posted on Jun 28, 2012
  • Felipe Costa Jun 28, 2012
    PHILIPS INFORMATION: HIGH SECURITY
    When the set is in the high security mode, the Setup Menu can only be accessed by a Institutional Setup Remote Control.
    OFF - This allows access to the PBS Mode Setup Menu via PBS Setup Remote Control or via Standard Remote Control (using a special key code sequence).
    ON - This allows access to the PBS Mode Setup Menu via the special PBS Setup Remote Control only.
    PHILIPS TV PBS MODE INSTRUCTIONShttp://www.hospitality.philips.com/docs/...
Unlock 21ht5403/oz1
Posted on Jul 14, 2011
    New Friend:
Digit buttons 3,1,9,7,5,3and the mute button followed by 0
Posted on Dec 23, 2013
  • Selene
    Selene Dec 23, 2013
    Digit buttons 3,1,9,7,5,3 and the mute button followed by 0 to shift through inputs
  • Terry Armz
    Terry Armz Jun 22, 2017
    this one worked for me
Get a Phillips universal remote (Walmart about $8.00) and one of the Phillips codes will unlock the tv and put it in normal use.
Posted on Nov 03, 2011
    New Friend:
Hi i have an old tv philips 28pw6518/05 and i don't have the remote control and is block on mute ....help
Posted on Apr 16, 2013
    New Friend:
I board ratter code my tv ohilips 26HF7875 / 10 and I was unable deblocker it. s v p help me
Posted on Oct 10, 2015
If you're looking to "unblock" the inputs, (for example; connecting a dvd or a xbox, ps, etc) it is possible to do it if the tv is a philips...just follow this instructions to access the menu:
Use the Digit 0 -9 buttons to press digits
319753 followed immediately by the mute
button. Note: Digit buttons 3,1,9,7,5,3
and the mute button must be pressed
successively within 20 seconds for the
TV setup menu to be activated.
Then you just need to create another channel, add the input (vga, svideo, avg, hdmi, etc...) and store the channel
Posted on Nov 07, 2008
  • 6 more comments
  • clarky141088 Oct 04, 2010
    i have got menu up but when I add channel it dosent bring the ps3 screen up?
  • Mike Radocha
    Mike Radocha Mar 24, 2012
    You just saved me from a huge headache! Thanks!!!
  • Sam8247 Apr 02, 2012
    Whoa. In London Raddisson now and that totally worked. thanks!!
  • shishender Jan 29, 2013
    hey i've same tv but suddenly it sounds blocked wot should i do
  • martybolad
    martybolad Mar 05, 2013
    Great..... It worked for me. Cheers
  • mak drimmakkos Oct 12, 2013
    perfect!!! worked and i thought in the beginning it was not true
  • Illumation Streambutler
    Great man, wonderful, thanks,cheers!
  • Jamjam Dec 10, 2017
    Hey there anonymous, I did what you said but my remote wont even let mo scroll down to change it please help.
    Jhasywockeez@yahoo.com
    New Friend:
    Problem Solver:
Hello my philips tv 23hf5474 / 10 pilot trying to type in the code 319753 and the mute button and the menu jumps on me and wants to switch the tv from pc to xbox etc .... Is there a possibility of another entry in the menu and switch ?? please help my email natalia.szprotka@op.pl
Posted on Dec 25, 2014
    New Friend:
How to switch your hotel Phillips 32HFL5662L/f7 to HDMI if you need to.
1. You will need a serial DB9 M-F cable, your PC with a serial port and a terminal program like Hyper Terminal or Putty
2. Set your baud rate to 115200, n,8,1 connect to rear RS232 on TV
3. Unplug the AC adaptor connecting the little smart box on the back of the TV. The TV may plug into this adaptor as well, so just plug the TV back into the wall. If you do not, the LCD TV will try to switch back to cable after you select HDMI.
4. Power on the LCD TV and you should see data on the PC screen in readable text.
5. You must send a carriage return after each command <cr> (the enter key on your PC)
6. Use only small letters (no caps)
i - info
u,d,l,r - Up, Down, Left, Right
p - PIP window toggle
To set to HDMI use the following sequence:
i <cr> (menu)
d <cr> (down)
d <cr> (down)
r <r> (right)
then use 'd' and 'r' to select the right input
Posted on Jan 29, 2013
2 Suggested Answers
SOURCE:
SOURCE: How to unlock AV on hotel tv philips HT5504/01Z?
mon tv mise en vielle apres toutes les 15 minutes
Posted on Feb 10, 2011
Can i get ur help or not am still waiting on a reply on my question about my philips tv
videos
9k= 1:54 How to lock and
unlock ISF modes
on Philips TVs?
TV Calibration with Darko YouTube - Feb 15, 2016 z 0:45 How Do You
Unlock A Philips
TV?
Wen Wen YouTube - Aug 14, 2017 9k= 2:23 PHILIPS HIDDEN
SECRET SERVICE
MENU/MODE
Carl Cosmos YouTube - Apr 15, 2016 2q== 1:09 How to unlock your
Philips
iTech Unlimited: Unlock... YouTube - Jan 30, 2015 z 1:20 ********* a locked
Philips 25u604 TV
for composite in.
CNLohr YouTube - Dec 23, 2012 9k= 0:28 How to Access
Hotel mode on
Philips TV
Carl Cosmos YouTube - Aug 31, 2016 9k= 1:14 how to unlock a
hotel tv/remove
hotel mode, use
HDMI on hotel tv
draai een keer in het rond... YouTube - Nov 16, 2016 9k= 0:46 HOW TO UNLOCK
PHILIPS MONITOR
CONTROL
Vrushank Maharajwala YouTube - Apr 30, 2013 z 2:45 Unlock Hotel TV
inputs
Channel88 YouTube - Dec 20, 2016 z 1:47 How to make your
hotel television,
like LG TV, allow
you to change ...
Margebird YouTube - Mar 24, 2016
How to lock / unlock a channel in Philips TV? - Philips - Canada
https://www.philips.ca/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
How to lock / unlock a channel in Philips TV? Press the 'MENU' button. Press the cursor right. Press cursor down to select CHANNELS. Press cursor right. Press cursor down to select CHANNEL LOCK. If the PIN code is correct, the channel list reappears. Select the channel with the cursor up/down and press the 'OK' button ...
How to lock / unlock a channel in Philips TV? ' Philips
https://www.usa.philips.com/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
Locking/Unlocking channels in Philips TV ' Philips
https://www.usa.philips.com/c-f/.../lockingunlocking-channels-in-philips-tv
  1. Cached
Published: 2017-03-02 ' Make sure remote control is in TV mode by pressing 'SELECT' button repeated until 'TV' lights up green.
Jun 21, 2018 | Philips Televison & Video
Unlock Philips model # 37HFL5581V/27
Hotel TVs use unique remote codes so guests will not steal the remotes. A universal remote is unlikely to contain the code.
Jul 27, 2016 | Philips Televison & Video
I got a free tv from a hotel, it has no remote. Can I use a universal remote to add channels to the tv? It only goes to channel 69. Also, can I plug in a dvd player? I can't find anywhere on the tv to plug...
Often these commercial TV's are just vanilla types catering for TV alone. The43 cable channel is possibly the only other alternative that is a money maker for the motel/hotel. They try and prevent people from connecting their own DVD players to their equipment so they are the ones who make the $$.
It is possible to use a Universal remote providing it is capable of being controlled by a remote.
Philips code is 0054 , you can only try!
Please rate my help++++Thanks for using FIXYA
Nov 21, 2009 | Philips Magnavox 27MS343S 27" TV
Aug 30, 2009 | Philips 20PT6441 20" TV
I have a philips tv whith no remote from a hotel how can i program it so i get all channels ?
If this has been a hotel TV then you cannot tune it in manually as the Hotel Mode will be activated & can only be re set to normal TV use by using a specific code from the remote control. The only other way is to re-initialise the internal memory using software that is only obtainable from a Philips dealer.
Jul 12, 2009 | Philips Televison & Video
How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
Jun 30, 2009 | Philips 20PT6441 20" TV
Stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Jan 16, 2009 | Philips RC2573 Remote Control
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Please helf
Check out this site for the correct codes bud.http://www.thompsontv.com/rcarc.html
Jul 30, 2008 | Philips RC2573 Remote Control
Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Oct 17, 2007 | Philips 36PT41B TV
Philips 20PT6441 20" TV Logo
63,937 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
