Question about GE Dishwashers
Dishwasher not getting water water valve is on and i tapped float valve it did not help
  • 5,081 Answers
The most possible problem is that the water inlet valve has failed ..
Check this video
Please check the video .
It is quite technical and please don't deny the credit to the expert by voting him low if the answer is valid and cannot be tried at home.
Posted on May 19, 2011
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
Dishlex Global 310 dishwasher fills then stops with flashing "fast" light
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jul 13, 2008 | Dishwashers
Mine DU1055XTSS3 is not taking on water after initial rinse.
test this steps and fix it. GOd bless you
Water Inlet Valve
Float
Float Switch
Jul 30, 2013 | Dishwashers
Does not fill with water.
follow this steps and fix it. God bless you
Water Inlet Valve
Float
Float Switch
Jul 08, 2013 | Thermador 24 in. DWHD64CS Stainless Steel...
My portable dishwasher won't fill? Please help!
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 20, 2011 | GE Dishwashers
Dishwasher runs but gets no water...
Hi
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
Power works no water into unit
hELLO THERE:
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 19, 2010 | GE Dishwashers
Dishwasher - no water coming into it
If there is no water coming in the machine check first the water supply has not a tap and this is closing.
If water is supplied regularly, then the problem is either with the inlet valve or the float switch.
See the following indications from repairclinic:
" Water-inlet valve
Float switch
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it."
Aug 29, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Hi i have a whirlpool 6adp951-3awh dishwasher that wont fill up i was told it could be the valve close to the tap
if this helps please vote me a fix ya
Jul 18, 2008 | Whirlpool Dishwashers
No water entering machine
IT COULD BE THE FLOAT SWITCH ASSEMBLY> PLEASE READ THE FOLLOWING VERY CAREFULLY AS WATER AND POWER DONT MIX WELL Before testing the float switch, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. When the water in the tub lifts the float to a set point, the float switch is triggered and it shuts off the water inlet valve, stopping the flow of water. If the float switch is defective, the tub may overfill.If the float switch is obstructed or corroded it can prevent the tub from filling by holding the fill valve off !!so locate, check and clean. To access the float switch remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. Note the location of the float in the dishwasher's tub and you will find the float switch beneath it in the access area. The switch has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multitester to test for continuity. Set the multitester to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. With the probes still in place, depress the button or lever on the switch and the reading should change to the opposite extreme
Jan 19, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
226 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
