Posted on Aug 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Brother MFC-5840CN will not print yellow or mangta
  • Hayou Aug 14, 2008
    print yellow or magenta
Anonymous
Level 3:
Master:
  • Master 521 Answers
  • Posted on Aug 14, 2008
Anonymous
Master
Level 3:
Master:
Answers
521
Questions
0
Helped
162994
Points
1218
Remove and check the cartridges it would be empty or if full clean the nozzle and re insert it.
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
2answers
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
16helpful
3answers
How to install LAN Brother MFC-5840CN on Windows 7 when original CD only has XP driver. Windows Update list specifies MFC-5840CN USB, but machine has option for LAN - is the driver the right one?
You cannot use the full driver and software package now. BUT:
Printing is possible, scanning and FAX is not possible at the moment. You download the Vista driver (x32 or x64) from the official Brother site and install it with the Printer Wizard in Windows 7.
Brother mfc 5840cn printing lightly or either tthe page is completely blank
Your ink cartridge is bad. Either that or your computer ram (memory) is not enough while you are printing.
No black ink printing
Ah, solved already. Cleaning the black print head a few more times did it for me.
MFC 5840CN - no print
you need to go to brother.com for the solution
Out of memory
you need to clean out the units memory
Print data remains in the MFC’s memory
Re-start printing from your computer.
Print data remains in the MFC’s memory. The USB cable was unplugged while he computer was sending the data to the MFC.
Press Stop/Exit. The MFC will cancel the job and eject the page that is being printed.
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
2answers
Software users guide fro Brother MFC 5840cn
You can download the manual in pdf here:
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc5840cn_all.html?reg=us&c=us&lang=en&prod=mfc5840cn_all
install memory card. press scanner button. choose scan:card and select quality and type. there are somemore infos given withi the software manual (which can be downloaded, too).
k24674
ADMIN Andrew
ADMIN Andrew
