Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
When desired temp. is reached the water heater pilot goes off. I have replaced thermo-couple, it makes no difference. when water cools down, pilot must be re -lit manually. when it reaches desired temp. pilot will go off again. WHAT IS THE PROBLEM
Pilot will turn off if thermocouple is not seated fully in the flame, or if thermocouple is bad.
When replacing thermocouple, there are good videos on Utube.
Finger tighten new thermocouple then add 1/4 turn, so the insulator is not crushed.
Make sure new thermocouple is seated fully in pilot flame.
You might also need to clean out burner tubes:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Read manual for troubleshoot checklist, and recommended maintenance and advisories.
Cleaning the burner parts and combustion chamber should be done periodically.
I know it sounds old-hat to say read manual, except each model is slightly different with different recommendations.
Generic 22V40 manual on following link:
http://bostonheatingsupply.com/Rheem%20Res%20Gas%20Fury%20Water%20Heater.pdf
Page 23 has a few DIY steps that include replacing gas control thermostat.
New gas control can cost $60 - $120.
Also air in the gas line, low gas pressure, gas shut-off not fully open, pilot orifice clogged.
Problem may be combination of several factors, requiring clean out and replacement of parts.
If repairs cost more than $330, then buy and install new gas water heater from local box store:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 19, 2011
How do I make the flame of my water heater pilot bigger, it seems to little and goes out every day. I have installed a new thermo coupling but the pilot flame is small. Is there a place to increase th
If the pilot is going out, it may be from lack of combustion air intake. Make sure you have fresh air in the water heater room...one within 18 inches from the ceiling, & one within 18 inches from the floor. The size of the openings is determined by the BTU's of the water heater.
Dec 13, 2014 | Rheem Richmond 40 Gal Natural Gas 12 Year...
Why does the flame shut off before a hot to warm temperature can be achieved
I would question the Thermo couple. It pretty much runs the whole show. Inexpensive quick fix. It's the small tubing that is connected to the gas valve. The other end is a bulb that sits over the pilot flame.. Remove the old and match it up at the hardware store. Install new coupler ensuring bulb is directly over the pilot flame Common iten. The thermocoupler alks to the gas valve. If the pilot flame extinguishes (goes out) the bulb cools and shuts down the gas valve so the pilot gas feed doesn't permit raw gas to accumulate, avoiding the need emergency Services. . You will not get the heater to fire until the bulb is good and hot. The red push button ,when depressed will allow the pilot flame to be lit. Hold it down until the heater fires, indicating the T-coupler has reached its operating temp.Good Luck-Ned
Sep 10, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
The pilot will not stay lit after water in tank reaches desired temperature. After tank cools down pilot will relight and heat water again thyen goes out approximately 1-2 minute3s after water has been...
Thermocouple is getting weak... the extra heat from the main burner will keep it lit but after it goes out the thermocouple will then shut down..
Replace the thermocouple...
heatman101
Apr 30, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Enviro temp hot water heater. 1 week ago pilot out. Able to relight but would go out again once water heated to temp. Replaced thermal couple (tc) with same result. replaced gas therm/valve (t/v). ...
Remove your entire pilot assembly from the heater and gas valve. Remove the aluminum gas line that feeds the pilot assembly. There is a small orifice inside the pilot assembly that may or may not fall out when you take the line off. If it does not fall out remove it and be sure that the very small holes in the top of it are clear. It sounds to me like even though the flame is blue and in contact with the thermo-couple, when the main flame turns off it causes the pilot flame to wave away from the thermo-couple thus shutting it down due to a weak pilot. I have run into this several times and should do the trick.
Feb 02, 2011 | Water Heaters
Pilot would not keep lit. Bought a new thermal coupling and installed it and pilot still goes out when you release the knob. White Rogers coupling. Do I need a bigger hammer?
I take it is on an RV?
The placement of the thermo coupler would be important - but no bigger hammer required... lol
be sure your connections are good and nothing got pinched off...
Alternatively there are some systems which have a lock out which may have happened and you might need a reset or otherwise let it cool down completely
or it might not have been the thermo coupler to begin with...
Best regards
ck
Jan 05, 2011 | RTO Atwood Water Heater - 6 Gal LP
Pilot light goes out
if the unit goes thru the cycle of heating the water and when temp is met pilot goes out you need to replace the entire temp control if pilot goes out as soon as you release the pilot button you need to replace the thermo couple little copper wire the goes from regulator to inside burner...check for 800 number on front of w/h for warranty info..as regulator can be expensive
Dec 09, 2010 | Reliance Natural Gas Water Heater Control
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hello, My Rheem hot water heaters pilot light
make sure that it is pushed into the flame of pilot light good because if not it can cool off and go out.and make sure that no drafts are getting in to heater to blow pilot.like when you close or open the front or back door have someone open them while you watch pilot light to see if it flickers .
Oct 26, 2009 | Water Heaters
Water heater won't run long enough for hot water.
Common problem if the thermo couple goes bad.Replace thermocouple with a universial on.A common hardware item.
Dec 14, 2008 | Water Heaters
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
241 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
