Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
We have error code F14 on our stove Model num is FES366ECB
Kenwood model 790.47849408. How can I correct recurrent F14 error?
(F14) Misconnected flat cables have you replaced the board?
Try this solution Disconnect power; verify flat cable connections (P6 or P12)
Feb 03, 2016 | Ovens
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Maytag stove model JJW9530AAW not working
https://removeandreplace.com/2017/03/21/maytag-oven-error-codes-stove-range-fault-codes-causes-and-solutions/
Nov 20, 2017 | Stoves Ovens
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Jan 11, 2009 | Gaggenau EB270 Electric Single Oven
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Code F14
F14 is usually the fault code (open circuit) for the NTC sensor on the electronics module. I would suspect a bad connection from the oven temp sensor (located at the rear of the oven) to the electronics module. If you are able to remove the oven from the enclosure and remove the top and rear panels, (power disconnected!!) I would suggest checking all connections to/from electronics module. Also make sure door contact switches are secure and not loose (remove side panels) Oshie
Mar 22, 2007 | Gaggenau EB294/295 Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
27 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
