Question about Cub Cadet Street Sign- tractor lawn riding mower parts
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we could blow bubbles in the gas 1/2 tank. Finally it started draining. Started. Then quit in about 1 min. now wont start. lines are clear.
  • 927 Answers
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
Posted on May 19, 2011
  • Jim Culkin
    Jim Culkin May 13, 2012
    check your fuses under seat
John Deere 265 starting problem
To start ensure that is not a carb problem, and that the engine is not chocking because of incorrect carburetor settings. The carb should also taken apart and cleaned.
Try also running the engine without fuel tank cap, if engine runs fine replace the tank cap.
if carburetor, fuel filter, tank and fuel lines are ok it may be a faulty fuel pump failing. To test the fuel pump, insert a pressure gauge tool like this in the lines out from fuel pump.
Regards.
Jul 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Hp gas
Follow gas line from tank to carb. Observe bottom of carb. Remove screw holding carb bowl to carb. Clean bowl. Pinch off gas line with pliers. Ensure float falls down easily. Float up no fuel flow, float down fuel flow. Observe screw that hold carb bowl to carb, see if it has a whole thru it, clean with small wire, bread wrapper works good. Observe center fuel port, clean with wire. Remove pin that holds float and meter needle, clean port with wire. Reassemble. Ensure air filter is clean, oil is full, 30w oil, spark plug is clean and properly gapped. Replace air filter and spark plug once a year. Empty old oil out if any grey is observed in oil, this is moisture, can accumulate after winter storage. Clean out side of carb with carb cleaner to ensure choke can rotate freely. Always use Stabile in gas.
All newer mowers have a low oil shutoff.
May 09, 2013 | Troy Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Accidentally put mixed gas and tried to start. Blew white smoke after starting but wouldn't run. Drained tank and put premium back in now won't even start.
There will still be some fuel mix in your fuel lines and filter. Also it probably fouled your spark plug. Try changing the spark plug first, and probably buy an extra one or two to keep in case. Also either replace the fuel filter or clean it out good, oil will stick to the elements in the filter. It won't hurt anything to run a mix in a gasoline engine, just lubed things up a little extra. Let me know if you need anything else, Daniel.
Oct 13, 2011 | Polaris ATV
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
986 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
