Question about Sanyo Televison & Video
Screen is red and it take 15 to 20 minutes to get apicture
  • Sanyo Master
  • 6,771 Answers
The picture tube in the set is bad, overtime the emission drops until the picture becomes so weak showing poor color, it is far cheaper to replace the TV than having it repaired.
Posted on May 19, 2011
At idle 2005 4 litre mustang shows 50 psi at 75 degrees, when at normal temp pressure drops to 15,20 at idle. At 2,000 rpm shows 40 psi. This sounds low to me, is this normal?
That sounds normal. There would be specifications for it that you should check, but that sounds pretty normal. The specs probably show a pressure for idle at normal operating temperature, and another figure at a specified engine rpm. Or it may just have one spec at a certain rpm.
Dec 28, 2016 | 2005 Ford Mustang
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
MY screen turns red after the tv set has been on like for 15 minutes
Locate the master screen / Focus block with 6 adjustments and turn the red Screen down a little.
Nov 30, 2012 | Sony KP-57HW40 57" Rear Projection...
When tv turned on will get apicture for only a few seconds then screen goes black, but wil continue to have audio. Cannot pull up menu on tv either
Hello.The screen goes black means that the backlights of your LCD is not working.Maybe the problem is the power supply or the driver board of the backlights.They shutdown because there have a shorted parts on the circuit or power supply. Did you try to reset the power and turned on and get a picture or every time that you reset the power it will get a picture and the picture goes black?
Jul 02, 2011 | Sanyo DP19649 LCD TV
Screen image turns red after 15 minutes
Ur backlight video board it,dying.Micro processor have shorted,must change the backlight board.
Nov 24, 2009 | Polaroid FLM-3232 Television
How can i change my screensaver to apicture i want
go to the photo,press menu and it will give you an opton to use it as a screensaver
Sep 28, 2009 | Samsung S8300 Ultra Touch platinium-red...
AT THE BEGINING THERE IS APICTURE THEN DISAPPEAR
check the horizontal section of the TV. and re solder the pcb at the neck of the CRT, and the main board. check for any leak capacitor, oil discharge in circuit board.
Jun 11, 2009 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
