Question about HP PSC 1610 All-In-One InkJet Printer
When i turn the machine on It says in the display window "initializing" and that is as far as it gets.
  • bdaily May 19, 2011
    I have unplugged from the wall with the same results. It is not connected to pc.
  • 794 Answers
Hi bdaily,
There are two possible causes for your printer to always read "Initializing". First one is low-power problems exist and this is a common problem in many home offices because of the number of electronic devices concentrated in one area. The other one is,
if the computer is grounding out through the parallel or USB port. Here are the solutions you need to do to address the issue:
1. First, determine if the product uses a power cable or a power module for the power supply. If the power supply has a cable with electrical connections at each end, the product uses a power cable. If the power supply has a cable connected to a module or box, the product uses a power module.
2. Next, verify that the electrical connections and outlet are functioning.
a. If the product uses a power module, make sure that the power module part number is the same as the part number listed in the User's Guide to ensure that the correct power module is being used.
b. Unplug the power cable or power module from the electrical wall outlet.
c. Unplug the power cable or power module cable from any power strips or surge suppressors.
d. If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it back into the power module.
e. Disconnect the power cable or power module from the back of the product.
f. Wait at least 30 seconds, and then plug in the power cable or power module into the electrical wall outlet.
g. Connect the power cable or power module back into the product.
h. Turn the product on.
i. If the product still does not turn on, plug the product into an electrical wall outlet in another room.
If the product turns on, a problem exists with the power in the original room.
3. Verify that the product is not grounding out.
a. Turn the product off.
b. Disconnect the computer USB or parallel cable from the back of the product.
  1. Figure 3: USB connectionWhen i turn the machine - c00057172.jpg Figure 4: Parallel connectionc00057176.jpg
  2. Turn the product on.
  3. If the product turns on, replace the USB or parallel cable.
If you have completed all the preceding steps and are still experiencing a problem, the machine needs to be serviced by an authorized repairman or if it's still under warranty you may contact HP.
Hope it helps.
Thank you for using FixYa.
Posted on May 19, 2011
    President:
  • 1,285 Answers
Unplug it from wall / PC uninstall HP software...... lets start all over from the beginning install data follow the onscreen info connect to PC / wall... this should get you by pass the initial part and ready to print
Initially the machine showed a fuser error. after opening the machine moving the fuser back and forth and restarting the machine did a self diagnostic and came back with the message - "machine error,...
Press menu, start, menu and the up arrow one at a time in order. Maintenance should appear in the display. Arrow down until you see 82 and then press the menu button. A machine error number should be displayed. After getting the number press the stop key to get it out of maintenance mode. The error that is displayed will determine the problem. What number do you see?
Jul 13, 2011 | Brother MFC-8660DN 5-in-1 Laser...
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
LaserJet M2727nf initializes. Will print one page. Seems to "reboot" itself and gets stuck in the initialization process. I am left with the HP Logo being displayed with a couple of arrows in...
Is it still under warranty?
If yes call HP.
If no...you could have a bad formatter or DC Controller.
What step does it get stuck at in the init process?
Feb 17, 2011 | Office Equipment & Supplies
I have an Oki ES3640 Pro, the problem is that there's an error message on the front display saying "Replace waste toner box, waste toner full" but it isn't full, I put a new one in last week!...
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Jan 14, 2011 | OKI ES3640ex Color Copier
My Konica md#7020 copier does not power up to the "touch screen". When I turn on the main power switch the light indicating I am getting power goes on. However when I press the button to turn on...
After the sub power switch is turned on, the Konica name displays for approximately 10 seconds, until initial machine settings are established. Then, the Warm-Up Screen displays for approximately 6 minutes, until the ?xing temperature is reached. The Basic Screen displays after warm-up. Initial settings are shown on the next page. Except for Print Quantity, all initial settings can be changed by the Key Operator.
Jan 06, 2011 | Office Equipment & Supplies
Display is stuck on "initializing..."
1. disconnect it from any other devices.
2. turn the printer off and unplug it.
3. plug it back in and try again.
Dec 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
My Sharp 1551CS has a "4" and "H" flashing in the quantity indicator. Copier appears frozen.......HELP!!!
To reset the H4 condition on Sharp AL series copiers press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service. Good Luck and Thank You for using Fixya. WheatlandServices
Nov 29, 2010 | Sharp AL-1551CS Printer
Replaced drum and cant get rid of the red warning
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Sep 21, 2010 | Sharp AL-1551CS Copier
Reset drum
Hi there!
To reset the drum light you need to press the following keys in sequence with 4 seconds for the initial 4 keys
Step 1: You need to press "C" then please press the far left key ( called exposure mode key) then press the "C" key then the far left key once again.
So the sequence is -- C, far left, C, far left.
Note: Some model utilize two other initial codes, you might need to use one of those two alternate codes to get your display to go blank. The remainder of the procedure is absolutely the same.
The alternate codes are as follows: #, * , C, * or pound key ,star key, C, star key and also #, Interrupt key, C, Interrupt key.
If done correctly the display will go blank.
Then type in 24 as if you are going to print 24 copies of something.
Then press the "print" button.
Then type in 7 as if you are making 7 copies
Now press the print button once again.
You will now get flashing zero's on the display of the unit.
Turn the machine off and then on again and your drum light will be gone.
Sep 06, 2010 | Sharp AL-1651CS All-In-One Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
228 people viewed this question
Seeker5211
Seeker5211
