Question about Astar LTV-3201 32 in. LCD Television
Color adjustment I can't adjust the colors and yes I tried the menu botton but the colors are off. For example.....the faces are a different color and the baseball infield is green instead of the brown dirt. Where do I go to adjust the colors to the picture? Please advise. Thanks
  • Jules63 Aug 27, 2008
    Ivan I spoke to you on Sunday and you said you would call me back. I still can't program the colors on my TV. Please advise. Thanks
  • 40 Answers
Hello friend,
First try go to TV mode setting, menu, setup, you should get what you wanted to program the colors, If still doesn't work please contact me by calling # 323-767-6030 and I will go through with you.
Posted on Feb 17, 2009
No color on my Panasonic plasma TV
Try to adjust the input, for example hdmi or scart .
Try to connect a peice of equipmet you know works with colour , ie dvd, plastation, vcr , and see if it makes a difference
You did not say if it was like that all the time , ie on normal tv
Feb 03, 2016 | Panasonic Televison & Video
How to Solve error message Density High for Konica Magicolor 7540, Quality reduce after the message
it could be a number of things.you could try a full color calibration.otherwise , i believe you can adjust the individual colors also.try to press go and -value+ keys at the same time.see if the color adjust menu comes up.from there , you can print a color adjust page which will show many values and adjustment options.scroll around there to see different options.Or Still having Problem Then follow Us For
HP Support
May 02, 2014 | HP Color LaserJet 3500 Printer
Can't adjust the color, brightness or contrast so that there is a pure white color. Can this be fixed?
yes you can. Go to Menu, and follow the steps for adjust the color, brightness ,etc or restore the factory default in Menu
God bless you
Jul 31, 2013 | IBM ThinkVision L170 17" LCD Monitor
Color doesn't look like what is on computer screen... printing from InDesign and Photoshop... same results from each program.
first of all, your screen is probably not correctly calibrated to show the colors right. Same goes for your copier, try calibrating the colors. Press the menu button (it's a button next to the screen, looks like a star with a head around it)
- Then press Adjustments/Cleaning
- Auto Gradation Adjustment
- Full adjust
- Print page 1
- Put the paper on the copyglass, with the black toner facing the back of the machine.
- Press Scan
- Then Print page 2
- Scan page 2
- Print page 3
- Scan page 3.
Now the colors are calibrated. If it still doesn't match, try calibrating your computers screen so you can see the real colors.
Dec 21, 2010 | Canon imageRUNNER C3220 Color Copier
Problem black and white how to adjust the color.
First check whether you have set to the correct standard NTSC, PAL etc.
If confusing set it to AUTO. All you can try in the menu mode. Try adjusting color if the color adjustment is set low. Try different channel. Try DVD .
If the color still not there, it is a problem from the chromo control circuit.
Sep 24, 2010 | Televison & Video
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung 6768W DLP 2 yrs old Replaced lamp and now color is off Faces look like paint by number
possible solution:
http://www.avsforum.com/avs-vb/showthread.php?t=1050735
  1. You may need to adjust the index delay after the replacement. You will be able to tell because you may see strange color banding in any scenes that have colors close, but not quite the same, in tone. This is usually most obvious in face skin tones (i.e. “clay faces”). If you need to adjust index delay, turn off the set, wait for the lamp to cool down, then hit mute-1-8-2-power in succession. The set should turn on with the service menu popping up eventually on the left. I don’t remember which submenu “index delay” is under, but find it and usually it will need to be lowered. I believe mine started out in the mid-50’s and had to be lowered to 47. These numbers are different for each Samsung model, so just adjust until the picture is pleasing to your eye. By the way, the supposed “correct” way to do this is to make the reddish part of the test color bar appear the “most saturated”, if you have a color calibration device.
Oct 15, 2008 | Samsung HLR6768W 67" Rear Projection HDTV
Toshiba MW27FPX dropped it!
See if you can borrow a TV de-magnetizer (degauss) from a tv shop...if that doesn't purify the color, then the shadow mask inside the picture tube is bad = no repair unless CRT is replaced
and that would cost more than a new TV ! ...................T.
Jan 30, 2008 | Televison & Video
Faces too pink in my ip6700D
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Dec 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Color printing
Nov 16, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Astar LTV-3201 32 in. LCD Television Logo
164 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
