Question about Xerox Office Equipment & Supplies
Workcentrepro 575 will not reset after replacing drum and toner. still says replace drum. will not print, send, copy.
    President:
  • 2,072 Answers
This should reset that for you.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Posted on Aug 14, 2008
Brother 1510 replace toner problem
Assuming you have tried to replace an empty toner with a new or refilled toner cartridge. Some of these machine simply fail to recognise the reset activation lever on the side of the cartridge. You could try removing the end cap at the geared end. You will find a half moon shaped gear which needs to be lifted out slightly and rotated a quarter turn clockwise. replace any other gears and refit the cover. This resets the toner cartridge to "new" state. If you printer doesn't recognise this, you will need to get a manual reset keycode from brother. Please note - some folk reset used cartridges this way and re-use them. Used toner will contaminate the drum and give poor print. Any residual contaminated toner on the drum can contaminate a new cartridge and so-on. Refilled cartridges are fine if the cartridge is completely cleaned out first.
May 06, 2015 | Brother DCP-1510 Laser Multifunction...
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Can send faxes they can read fine but when i get faxes cant read them about a week ago paper jamed in the roller do i need to clean with what product
I assume you talking about a panasonic DP-190? Do not clean the drum you may gently wipe it down, realize the drum puts the image on the paper, nick it, grease from hands, ,etc will effect copy qualilty. Remove the toner cart. clean any toner spilled. Drum may need replacement, print a toner/drum resupply form to see if the machine prints them cleanly
May 08, 2009 | Office Equipment & Supplies
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Print problems with brother MFC-8860DN
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
168 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
