Question about Canon DC100 DVD Camcorder
I need to help on getting the DVD's copied to a larger CD. I do not have AV cord to plug in to the camcorder.
  • Canon Master
  • 17,970 Answers
If you want to shoot video and then edit it to take out wasted scenes, add titles and music, etc., you're taking a hit in video quality by shooting native with a DVD camera . This is because the video on DVDs is encoded to MPEG2, a compressed format. It's great as an end of the line format, but not for shooting source footage. Likewise, hard drive based camcorders, while convenient, tend to record in MPEG2 (only JVC gives you an option to record in AVI). This gives you the same problem. Additionally, you will also have to "re-encode" (also called demuxing) the footage into an editable format. It's a hassle for those of us who wish to edit our videos as a hobby.
However, for DVDs, you'll need to take that DVD and "rip" it to your PC and then encode it into a more editible format. I recommend DVD Decrypter or DVD Shrink. They will get your footage off the dvd and onto your PC. You can then use something like Videoera (PC) or Handbrake (Mac) to encode it to a more editable format. Depending on what editing software you use, you may be able to import mpeg2 and even VOB files directly. But understand that you're already starting with compressed footage, so the resolution quality will not be as good as if you had shot native with MiniDV tape and captured to your PC.
There is another solution to this...
If you record it in VR mode then you can play it back on any VR compatible player (most TV DVD recorders accept VR disks), plus you can edit the disc on the go.
The only bad thing with VR mode is that it will only playback on a VR compatible drive. If you have a VR disc and you put it into a PC this is quite fun 'cos PC's don't recognise VR discs (!?!?!?) they'll read them and attempt to play them in Media player but you get nothing. So here is the solution. You need to open up the disc in Windows instead of letting media player auto-run it,
There will be a directory there called DVD_RTAV go into that directory and you'll find 2 files in there, the larger of the two is your video file (it's got the extension VRO).
Copy it to somewhere on your hard disk and change it's extension to MPEG, open it with any software like media center, or VideoLAN and it plays fine (the weird thing is not even VideoLAN can play it when it's named VRO, normally VideoLan is quite robust about playing anything you throw at it - obviously not VRO files unless there called MPEG's!
Also once there MPEGs on your computer you can then burn them to full size DVD's using things like NeroVision!
Finally, I suggest look and buy the av cord for this and other jobs at future.
Hope this helps.
Posted on May 19, 2011
I have a camcorder Panasonic SDR-T55 and want to copy my pictures from built in memory into sd card but I don't know . Please help
You may not have that option.Most camcorders give you the option to either record to the built in memory or the SD card Flash Memory.The option to copy from the internal to SD card is device option. You can use USB, AV , cables to convert files to DVD or other formats to copy to Flash Media or DVD/ VCD/DVD RAM.Good Luck.
Jul 29, 2011 | Panasonic Video Cameras
Camcorder is a Canon Mini DV ZR100 in very good shape. While recording with an AV plug into two DVD recorders and the firewire plug into a Macbook Pro, the picture seemed very poor out of the DVD...
that is normal its the copy protection that taged
on the dis toc.....that is why the picture go black and disturbing color/ disconnect your firewire try this..
Feb 24, 2010 | Canon ZR100 Mini DV Digital Camcorder
Can not find software to run my ccd-TRV138 camcorder on windows 7.can i be helped?
Sony CCD-TRV138 is analog video-8 camcorder that can not be hooked directly with computer because computer needs digital data file where as this camcorder is an analog and has no digital file format.
If you want to transfer CCD-TRV138 movies in computer, you need to convert its analog Audio-Video signal into digital format then save it in computer for further process/ edit etc.
Hook CCD-TRV138 with DVD Recorder in AV Input and burn a DVD, this process will convert analog movie into digital data format, put that CD in your computer and copy-paste files in computer.
Hope this info will help you.
Thanks.
Dec 22, 2009 | Sony Video Cameras
Trying to copy from camcorder to disc.
You should connect your camcorder to an av input on your dvd,either scart or phono.Then put the dvd onto the input channel you have connected to,ie say av2,then your camcorder on play and the dvd on record.Hope this helps
Sep 07, 2009 | Televison & Video
Cannot copy video from JVC GZ-HD6 camcorder to DVD Recorder
If you can play the vision on your tv via an av connection you should be able to record it onto the recorder. the recorder can record anything thats being played on the tv even if the other device is connected to the tv via another av connection. try this & see if it works.
Mar 14, 2009 | JVC GZ-HD6 HDD Camcorder
Convert a Hi8 to cd
Hi 8 tapes are analogue and need to be converted to digital before a DVD can be made of them. You can pass the signal through a digital video camera to the computer to convert them. Only very short videos could be copied onto a CD as most video files are much larger than a CD's capacity.
I'm not sure about digital 8 but maybe the camera only has an analogue output? If the lead goes to RCA plugs - that is analogue. A firewire socket means a digital output.
Sep 01, 2008 | Sony Handycam DCR-TRV520 Digital Camcorder
Camcorder connect to Insignia dvd/vhs copier unit
connect to front press av input button. set it on av 2. make sure your tv input is set to v2-component.
Dec 24, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
AV jack
YES YOU MAY EITHER WANNA REPLACE THE AV(STEREO VIDEO CABLE) OR IF U HAVE HAD IT LESS THAN 90 DAYS CALL CANON FOR A REPLACEMENT 800-828-4040
Nov 30, 2007 | Canon DC100 DVD Camcorder
Sony TRV128 - Will not transfer sound to DVD
There is an S-video jack in the front of the cam, the S-video cable is rather inexpensive and available at most stores that have electronics.
Nov 26, 2007 | Sony Handycam CCD-TRV128 Camcorder
Canon DC100 DVD Camcorder Logo
42 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
