When I start the Miele W4840 washer, it is making a clicking sound then a buzzer goes off and says F63 call technician. I called the technician and he just left and now I started the washer and it is doing it again. What could be causing the clicking noise?
skyblue67
  • 71 Answers
SOURCE: Miele W4840 is LOCKED
hi try pressing in the heavy soil button to take off the child lock, good luck
Posted on Jul 19, 2009
SOURCE: miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Posted on Jul 03, 2010
SOURCE: hi,i have a washing machine miele w 3000 tech
Mine is W3844. Miele's technician said the Wather Path Control Unit (part # 6271992) need to be changed.
Total Cost: (HKD)
450 for todays check cost
1100 for the part
250 for the labour to change the part.
Posted on Jul 16, 2010
  • 251 Answers
SOURCE: My Miele 1374 washing machine
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Posted on Jun 14, 2011
  • 128 Answers
SOURCE: I have a Miele W4840
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
Posted on Jul 19, 2011
How do I fix this myself: Miele Softronix W 1734. Reports Error: "F63" When I look up that error I get: "Contact Miele technician"
either the controller is not working or the inlet valve is bad .could also be the pressure switch that tells the machine when it is full enough
Jun 05, 2016 | Miele Washing Machines
Miele W1203 washer, buzzer sound with no indicator flash. how can i fix it
It sounds as if there is a leak and water in the pan (bottom of the machine) the front of the machine would have to be removed to check and determine the cause of the leak
Aug 02, 2014 | Miele Washing Machines
Malfunction, the sentences "waterproof" shown on the screen
Remove the main board and check for moisture within the board, if seen use a dryer to warm off as this can make the board work erratic. Check and clean all the connectors and reset.
Aug 22, 2013 | Miele W4840 Front Load Washer
How to cancel programme once it is activated on Miele W502
Turn the machine off.
Turn dial to finish.
Turn power back on.
Select drain and start.
When drained you can begin again.
Nov 17, 2012 | Miele W4840 Front Load Washer
Miele w4840 door rubber seal relacement
i just replaced rubber gasket on miele w4840 it took lots of patience! there is a retaining wire on spring on front part this is easily removed. next there is a light and water line about 11 o'clock take this apart and unhook water line in order to remove these from gasket. next there is a locking wire on right side at 9 o'clock. i was able to get a flat head screwdriver and loosen the screw you can open about 1 -1.5 inch at this point the rubber seal can be removed. you have to carefully (painstakingly) put the new seal on. make sure everything is lined up right before replacing the wires took me about an hour as the gasket is difficult to put on back part on drum
Apr 16, 2012 | Miele W4840 Front Load Washer
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
Hello, i'm facing the following issue technical default F63 on the W5794 washing machine thanks in advance for your precious help regards
Hi vianney_dupa,
Your water path control unit is not registered by the PC Board. This is the Pressure switch / Water Level Switch. I'd kindly suggest you get a qualified technician to come and check your machine. If not well diagnosed it may lead to further damaging the machine.
Sorry, no quick fix here - This is were Miele machines get complicated O.o..
No need to vote my answer, I'll understand.
May 12, 2011 | Miele Touchtronic W1213 Front Load Washer
W4840 water proof system activated how to reset
1. Unplug the washer
2. Tilt the machine forward about 45 degrees
3. Water will start pouring out from the base pan. Have some towels handy to clean up.
4. Put the machine back in its position
5. Plug it
7. You should be ready to go
Causes
- You may be using too much detergent. Try lesser amount next time.
- There is a leak. If using less detergent does not solve it and this message keeps coming back, then the leak needs to be investigated.
Dec 10, 2010 | Miele W4840 Front Load Washer
Jul 19, 2009 | Miele W4840 Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
