Question about Maytag MER6772 Gemini Electric Kitchen Range
Hello please help me
My es300 is about a year and a half old we was painting our kitchen so we had it pulled out and unplugged. When we plugged it back in it spark one of the wires had came off somehow we put it back on and replugged it in and the time display come on and it the red light comes on showing the element is on but no heat both the top or oven part could it be a cutout?
  • 68 Answers
You have blown a fuse and also may have short curcuited it when you replaced the plug. Please get a serviceman or elecrician to fix it as it could be dangerous to leave it on.
Posted on Aug 30, 2009
Baking element not working
Hi, UNPLUG the oven! Remove the screws that hold the element in and pull it toward you. Hopefully they were kind enough to give you plenty of wire to pull it out. Then just unplug old element and plug in new one. Some models have a screws on the element to hold the wire on to it.
I hope this helps.
Please let me kow if I can assist you further.
Thanks
Vic
May 30, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
How to change spark plugs... 2003 ES300
Hi!
You need New Spark Plugs, Spark Plug Wrench Socket and Wrench Extension (at least 2-3 inch) size 10 socket and/or size 12 socket.
First of all, please check where the spark plug cover is. Once you figure that out there will probably be size 10 or/and 12 bolts holding it down. Take that off and there you will see sensors connecting to each other and holding the spark plug in the cylinders. Unplug all the sensors and pull out the circular plugs holding the spark plugs down. Pull them out and make sure that you don't drop anything into the cylinderes. You can look down into them and see the spark plugs. Get your spark plug wrench, extension, and socket wrench and stick them down in and push so that the spark plug wrench grabs them. Then unscrew the plugs, pull them out and put the next ones in and tighten them down. Just connect all the sensors, and put the cover back on.
Thanks for using FixYa and do rate if found this solution helpful.
Thanks
Rylee
Mar 27, 2009 | 2003 Lexus ES 300
Oven bake element will not turn on.
Welcome ,
This means you have one or more relays that are defective.
Rather than spending your hard earned money randomly swapping out parts.
Call service and get it done in one shot and save money on parts. all that you spent on unnecessary parts could have went to a service call and a good meal this evening from your fine oven.
bless you,
huum
relays are the problem.
Please remember to leave a fine rating for our fine solution!
Dec 07, 2008 | Frigidaire FEF366 Electric Kitchen Range
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
Range top caught fire
Hello vyoshikawa,
Welcome to fixya,
You said, the igniter had started by itself!
Please , do not play around with this issue!
You can try to pull the plug on this. And use service to diagnose this. We do not want you or your family to have a fire in the middle of the night.
If you need to use the range till they come and diagnose it, pull the plug when you are finished.
Pulling the plug for 5 minutes will perhaps reset the system, BUT this is no replacement for getting service in this case!
Let me know what happens.
Please remember to leave a rating!
Huuum,
Oct 02, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Right front burner not functioning properly
Hello amerwit
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Sounds like you have a bad switch that needs to be replaced in your electric range!
How old is this range?
You will need a good service tech, hands on for this!
Let me know how it goes,
Huuum
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old range
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ranges you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Aug 29, 2008 | Maytag MER5775Q Electric Kitchen Range
Paint peeling off around stove top burners. model#MGR6775BDS Serial # 13115412Lp Less than 1 yeart old have not cooked acid or sugary items.
You are under full Warranty for one year!
Do not procrastinate this matter!
Call whirlpool and demand a replacement!!!!!!!!!!!!!
Tell them this unit is defectively painted!
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Maytag Kitchen Ranges
Electric Glass top range broken
Hello leebenchang9 ,
Welcome to fixya.
You can find a fixya repair service near you by finding this section on our site and entering your zip code! The service arrangement can give you a price!
How old is your range?
Please do not forget to leave a rating.
Thank you Huuum
Find Kitchen Range Repairman Near You: Browse the Repair Directory
Repair or replace?
Thank You, HUUUM
Jul 29, 2008 | Maytag MER5775Q Electric Kitchen Range
RCA 32V420T (32 inch)
I think that vertical deplection IC of you tv set is shorted. Please check also the YOKE of the unit, its maybe grounded.
Sep 10, 2007 | RCA 32V420T 32" TV
Painting
Hello there, You can paint your kitchen hood with special paint (appliance epoxy), but you might want to take it to a professional. It is not a simple job to do. have fun!
Aug 07, 2007 | Bosch (DKE9465EUC) Stainless Steel Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
66 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
