Question about Acer AOpen AX 6BC (91.87810.451) Motherboard
Ihave a aopen computer. The other night when shutting down -- before the windows statement that it was ok to turn off the power. The lights on the power and reset lights flickered. I latter tried to power up the computer but nothing happened. I bought a power supply and the computer would not power up. Is it possible there is a short on the motherboard?
  • 63 Answers
Heya,
Yes, it is very possible when a power outage happens, the power supply can get a surge through it and cause the mainboard to stop working. I see this all the time in my line of work (supporting retail hardware).
If replacing the power supply hasn't resolved the issue, then the next thing you should try is to take the system to a bare-bones state to see if it boots, if it does, slowly add the hardware back.
By bare-bones state, I mean remove all but 1 stick of RAM (and if it doesn't boot, try a different stick, but only have the 1 in there), remove all USB devices, even keyboard and mouse. Basically you want to have the mainboard hooked up to the power supply, the processor, 1 stick of RAM and a monitor. If it boots when you do that, there's a problem with something other than the mainboard.
Add the hardware back one piece at a time (annoying, I know) booting the unit after each piece is attached, when you add a piece of hardware and it won't boot, set it aside, get everything else working, then add it back again, if it doesn't work, then that piece is your problem.
Good luck! hope this helps
Posted on May 19, 2011
  • Acer Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
My Toshiba A665-S6086 is having 2 problems: 1. Everytime I started my laptop today, it would load up, and then it would freeze. My mouse moves, and I can see everything (desktop, taskbar, etc.) When I move...
In safe mode- go to event viewer, and look for the fault- it sometimes is a windows update not installing properly, or, it could be a graphics driver problem. The yellow symbol similar to a statement, could give a clue, or, other shown faulting code.
Right click computer, left click manage, and then left lick on event viewer, and let us know what it says.
Mar 14, 2017 | Toshiba Satellite A665-S6086 Laptop
HPvs17x power flicker on/off no image, 3-10min after image ok!
More likely to have failing power supply problem due to bad caps, look for caps with bulging top first and post back what you see inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 02, 2010 | Computers & Internet
My HP won't shut down. I hold the button to try a
Try this: Go to Control Panel-Display-Screen Saver-Power-Advanced tab and make sure that after the statement "When I press the power button on my computer" choose Shut down. Then turn off your pc with the power button (if it does not work unplug it, then try the button after Windows complete it's boot-up. Let me know how it went.
WBTech
Feb 01, 2010 | HP Computers & Internet
My monitor turns off every 2 minutes, even when you re power the monitor it will just shut down randomly. anybody knows whats wrong with it? and how much it will cost for repairs?
does it always shut down every 2 minutes? or is it "random" like you said? i ask because it can be configured to turn off as desired (that is if it is not used).
http://www.tothepc.com/archives/configure-your-computer-to-turn-off-automatically/
i think this website might be able to help you
Dec 16, 2009 | AOpen F2715 (Black) LCD Monitor
Last night my Compaq desktop was working completely fine and I shut it down normally using windows. Now this morning the power button wont turn the computer modem on! There is a green light that is...
try to umplug the modem from the motherboard last pci slot on the botom of the case if that works ok if not try new power supply if still not working problably bad motherboard thanks
Oct 13, 2009 | Compaq Presario 5000 PC Desktop
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
Desktop Will Not Turn On
shut the tower off or unplug it form the back for a few minutes
plug in back in and then try to turn it on
you may have a power supply failure
let me know what happens
Jan 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Power problem
ok..I do believe thathe cable is connected to the monitor, right? have you checked your system unit if its also turned on? if it does, try to reseat your cable wire of your monitor( make it snugged fit and tight to avoid loose connections) then try to replugged it to the power source..
Jan 27, 2008 | AOpen A50P (Beige)
Hard drive shuts off?? I think.
replace your power supply, you need to upgrade this to at least 500watts to avoid problem like this, there is no problem with your hard drive its your power supply
Dec 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Acer AOpen AX 6BC (91.87810.451) Motherboard Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
