Question about Marc Ecko Watches
My pin to my band is broken it needs to be replaced Models e15035g1 I need part a.s.a.p
  • 2,334 Answers
Which pin? In bracelet, or in the place the bracelet is attached to case?
Posted on May 19, 2011
Marc ecko model e15035g1 pin and crown parts where can i get them
im tryning to make the links shorty how can i do that?
Nov 30, 2011 | Watches
The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
Jul 21, 2010 | Seiko SGF204 Wrist Watch
Replacing watch band on pathfinder pas410. can't get pins out to replace band.
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
I have a women's kc1239 wrist watch. I've brought it to my jewelers to fix the pins near the clasp, but noticed the 2nd pin down from the watch face was broken, too. My jeweler said they cannot fix this...
I am sorry but u are going to need to replace the watch band, the jeweler is correct, did he suggest the correct replacement band, he should have a selection of bands that will work with this watch.
Dec 07, 2009 | Kenneth Cole KC1239 Wrist Watch
Broken band
You can go to walmart and they sell bands and also try the flea mkt. They have all different brands that fits your style and even change the pins.
Nov 30, 2009 | Diesel 3 Hand Brown Digital Quartz Display...
Kenneth Cole Watch 3574 pin in length has broken
are you talking about the band pins or the lug pins? most watch repair stations will have lugs and pins, and will replace for about $5...any more and you will be getting ripped off. Lug pins are a pain and unless you have the proper lug tools, you can end up scratching the finish of the watch...be careful!
Jul 06, 2009 | Kenneth Cole KC1169 Wrist Watch
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Broken Watch band
    you probably just need a pin to secure the links back together. an authorized Movado retailer will have the tension or screw pins to put the band back together. They can also order additional links if needed. you can find a local retailer on www.movado.com
    Jan 07, 2009 | Watches
    Leather watch bands are broken
    The "gizmo" would be the pin that attaches the watch to the case. You can easily purchase a replacement pin or strap at any store that has watches (even Wal-Mart). These are very inexpensive and each one will cost you less than $10.
    Jan 03, 2009 | Fossil AM3695 Wrist Watch
    Need to repair band broken at the claspe with short pin.
    Any watch shop Will sell them. also even buy them online.
    Regards;
    _-_-_-_Viper_-_-_-_
    Sep 22, 2008 | Navy Seal Luminox Watch
    Watches Logo
    501 people viewed this question
    Top Marc Ecko Watches Experts
    Jimmy Accardi
    Are you a Marc Ecko Watch Expert? Answer questions, earn points and help others
