Question about Blenders
We had just purchased 3 Hanabishi blenders from PureGold, and each one of the people that we gave them to is saying how bad this blender is, It leaks, they tried to tightened the bottom as hard as they could, it worked for a while until they took it apart to wash it and the gasket broke to pieces. We need gasket, where can we get more of these things?
SOURCE: Jar blender blade bottom screw on piece
villaware 1-866-484-5529
Posted on Nov 20, 2007
SOURCE: Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Posted on May 24, 2008
  • 16 Answers
SOURCE: 40 yr. old Waring blender
plz cont -- 23051554 \ 23095757
Posted on Aug 05, 2008
  • 5 Answers
SOURCE: COOK'S ESSENTIALS BLENDER CESS700B GASKET
Go to: http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3694&secid=53&linkon=category&linkid=91 My Cook's Essentials is just like the Back to Basics model SE 2000. Yours may be one of the other models, click on replacement parts at he top. I hope this works out for you too.
Posted on Feb 12, 2009
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
Broke glass blender RN#73277 model number.
Do you know the brand of the blender? I am not finding anything in reference to the RN# you gave. Usually on the front of the appliance or under the motor base you will find the brand and model number. We should be able to find from there if replacement parts are made for the blender or not.
Apr 14, 2015 | Blenders
Where can i purchase a jar for this blender and at
try looking at abtec.com. they have parts for the Hamilton Beach 50754 blender.
Jun 11, 2010 | Hamilton Beach 50754 WaveStation 10 Speed...
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
The blender stopped working
the motor is burnt. replace with the same motor or have it rewound.
Aug 24, 2009 | Kenmore Blender Single-Speed Blender
The black rubber that blender sits on is breaking off.
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Jun 26, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Leaking Blender
yes you have a defective rubber seal on the pitcher base
Apr 16, 2009 | Back to Basics Blender Solution 5500...
Blenders Logo
101 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
