Question about Refrigerators
What is the best position for the temperature to be turned to, i seem to have it to cold and it is freezing everything?
  • Refrigerators Master
  • 2,696 Answers
It might not be the control!!!!if there's a damper in your machine the damper door might not be closing and cold air is blowing into the fridge all the time.next time send the brand name and model number,if the control goes up to 9 set it on 4
Posted on May 19, 2011
Won't stop running even on the off position on temperature. Freezes everything
the "o" position is as cold as you can get
try setting up around 4 and see what happens
Apr 29, 2015 | Black and Decker USA Black & Decker 2.7 cu...
Calibrate temp
You need to balance the temp settings. The freezer controls everything and it you have the refrigerator set wrong then the freezer tries to compensate. This means that things get too cold
Apr 03, 2014 | Whirlpool Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Our crosley refrigerator freezes our food, and if you turn it down food get's to warm the refrigerator is 2 yrs. old
Assuming your food gets warm when both control settings are at normal positions, or for that matter, freezes, in the refrigerated section, at normal positions, your problem will most likely be caused by a faulty cold temperature control not sensing temperature correctly, and needs to be replaced.
www.FixMyFridge.net
Mar 08, 2010 | Refrigerators
Fridge side began freezing everything then the fan
Generally speaking, sounds like you may have the frozen condensor problem that is so common
because of the design flaw in the Samsung products.
Turn it off, empty the freezer.
Study the back and look for formed ice around the seams.
So it got too cold, and now it is still too cold, or not cold enough ?
May 08, 2009 | Samsung RS2556 Side by Side Refrigerator
Ice maker not working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Dec 05, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice on whirlpool refrigerator
Hello.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
Dec 05, 2008 | Whirlpool Refrigerators
Everything freezes
Sounds like it has a damper problem. If the damper is stuck in the open position cold air will continually flow into the fridge. Have to be careful diagnosing on these because most are controlled by a board and that could be the real problem. Need to check the damper motor for resistance with an ohm meter first.
Nov 17, 2007 | LG LRFD21855 Stainless Steel French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
